Thanks for the reply Brian
I must be a bit dim, but can't work out where 300 and 1000 come from.
The cutting surface speeds ( I looked at 3/8 and 5/8) works out to be 62.83fpm for 4 flutes, 100 for 2 flutes at both dia.
If Tooth Load = Feed Rate/ (RPM x No teeth) then the TLs are double for the 2 flute (.001" vs .002 for 3/8, .002 vs .004 for 5/8) .
I presume that a factor of 2 is not an issue for the home workshop. The figures seem to work out ok for me when I blindly use them. Better not to think too hard i suppose
