Titan HSS drill bit sharpner
Home Forums Workshop Tools and Tooling Titan HSS drill bit sharpner
  • #282392
    Mike Brett
      @mikebrett89695
      Hi
      As my collection of blunt drills is getting ever bigger I was considering investing in a Titan HSS drill bit sharpener , sold by Screwfix. Has anyone had any experience of using these and do they give reasonable results.
      Cheers Mike
      #18400
      Mike Brett
        @mikebrett89695
        How to sharpen drills
        #282414
        John Rudd
          @johnrudd16576
          To be blunt ( pun intended! ) they are absolute sh****
          I had the Clarke equivalent….there's no way if ensuring both facets are ground the same….gave it away…!!
          Save your hard earned and buy the Sealey SM 2008…that was what I bought…
          Edited By John Rudd on 04/02/2017 18:45:49
          #282526
          Mike Brett
            @mikebrett89695
            Many thanks for info John, looks like its the Sealey then.
            Cheers Mike
            #282553
            Dave Halford
              @davehalford22513
              There are several 'brands' of this grinder, just with different badges and black plastic or grey.
              Don't pay more than 50 something for it.
              Don't force it – people on here have complained about the wheel not lasting.
              Personally, I have the Holzmann version because they sell them 10 miles from me.
              I thinks it's fine, but I only use a light touch as there's no cooling method, rather than shove it in like my life depends on the fastest sharpened drill ever.
              #282569
              Allan B
                @allanb
                I have the Clarke version, as said above, don’t use too much pressure and a bit of a wiggle and I have had some very good results out of it, wouldn’t say it is as good as a new bit as the edge doesn’t seem to last as long, but well worth the saving on new drill bits.
                Allan
                #282580
                Jeff Chilver
                  @jeffchilver13861
                  The Potts drill grinding jig is extremely good as it corrects the point geometry for each size of drill . I don't think anyone sells it ready to use but a kit and drawings are available from Hemmingway's . You do need the kit and ability to work to close angular limits it you have a go at one .
                  #282601
                  Roger Williams 2
                    @rogerwilliams2
                    Hello all, I was recently given one of the Clarke drill sharpeners as a gift, still had the price on it, £24 . I thought it wouldnt be much good because it was " junk " ( thats what it says on the internet !!!), but it actually works well.
                    #282606
                    Ray Creighton
                      @raycreighton18996
                      Hi,
                      Years ago I purchased a USA made Drill Doctor 300, BEST WORKSHOP TOOL I EVER PURCHASED !
                      If I have a blunt drill, it takes the Drill Doctor less than one minute to to sharpen to a accurate sharp finish.
                      I will be upgrading to a Drill Doctor 750X soon to expand the size and type of drills I can sharpen eg Split point drills
                      HTH
                      Ray Brisbane OZ
