The stand alone weight for tower clock
Home Forums Clocks and Scientific Instruments The stand alone weight for tower clock
Viewing 25 posts - 1 through 25 (of 32 total)
  • #812864
    dk0
      @dk0
      I designed and built an automatic weight for a tower clock.
      The operating principle is called “Monkey up the rope.” Essentially, the weight contains a gear motor and lead plates. The motor winds itself up the chain when it has descended to a certain level. This system has the advantage of keeping the pendulum constantly loaded. Another advantage is that the application not requires machining or mechanical modifications to the antique clock. I’ve made a dozen of them, and they’ve been working perfectly for over five years. The overall weight is adjustable using additional plates and varies from 12 to 25 kg.
      157
      bernard towers
        @bernardtowers37738
        That would make a good article for the magazine, any more info?
        #812915
        Nigel Graham 2
          @nigelgraham2
          I agree!
          It’s an interesting solution to an old problem and it would good to read about in ME&W.
          #812922
          dk0
            @dk0
            No problem providing information about this product.This project was born from the need to automate antique clocks without compromising or altering their originality, as required by art heritage laws.
            The application only requires the diameter of the rope barrel to provide the corret diameter of the roller chain crown. BURST001_COVER 10 (002)
            The kit consists of the weight assembly + 5 meters of roller chain + a crown that encircles the barrel + a small 220/12-volt transformer.
            IMG_20211107_165438 (00x)
            #812929
            Bazyle
              @bazyle
              An interesting concept and food for thought. I think I would have a short chain and just attach it to the end of the rope to avoid having to get ‘into the works’.
              #812940
              dk0
                @dk0
                I don’t understand how it could work…. the weight just attach it to the end of the rope .
                #812941
                duncan webster 1
                  @duncanwebster1
                  Love it, almost makes me want to make a conventional clock so I can have the weight shimmying up every so often
                  #812945
                  John Haine
                    @johnhaine32865
                    Another approach would be to drive the “monkey” with a stepper motor synched to the clock pendulum with some electronic “gearing” so it climbs up as fast as the chain rolls down.  Would need much less height.  Need quite a lot of mechanical gearing between the stepper and sprocket but steppers with gearboxes are quite cheap.
                    #812950
                    duncan webster 1
                      @duncanwebster1
                      If you go down that route you could drive the escape wheel direct from the stepper via a torsion spring, sort of permanent remontoire.
                      #812976
                      Nigel Graham 2
                        @nigelgraham2
                        That would be a significant change to the way the clock works, though. Fine for a new project, and no doubt interesting to build, but not when maintaining the original.
                        The only “modification” dk0 has made, is to fit a sprocket to the rope-drum – readily reverted to full weight and cord power.
                        Also, would using a torsion-spring remontoire place a brief interruption to the escape-wheel drive each time it acts?
                        #812977
                        duncan webster 1
                          @duncanwebster1
                          Don’t think so, escape wheel on one end of torsion spring, stepper on the other. Escape wheel is driven continuously by the wind up in the spring.
                          #812989
                          John Haine
                            @johnhaine32865
                            The scape wheel of a Harrison clock is driven by a much coarser stepping remontoire than a stepper motor. I first suggested this approach in an HJ article a few years ago = given that “Clock B” uses a lever lifting a weight and pivoted off the minute arbor with a worm motor drive controlled by a mercury level switch, the stepper remontoire would probably work better and take almost all the torque load off the train.
                            #813098
                            dk0
                              @dk0
                              Remaining on the subject of restoring antique tower clocks, another aspect requiring attention is synchronization with the exact time.
                              The device designed is an electromechanical actuator controlled by a small PLC. Every 24 hours, the synchronizer activates a V-fork that indexes a pin on the minute wheel, correcting any errors of the pendulum.
                              20231114_121014A
                              #813101
                              dk0
                                @dk0
                                With these two simple devices, automatic weight winding and the exact time synchronizer, any old tower clock can be returned to its glorious function.
                                #813113
                                Marcus Bowman
                                  @marcusbowman28936
                                  That’s an interesting device.
                                  Does that forked device cope with both slowing the minute wheel when the clock is running fast and advancing it when the clock is running slow?
                                  Are the limits on adjustment set by the aperture of the fork?
                                  I assume this requires a pin to be added to the minute wheel?
                                  Does the device have its own GPS-locked internal clock? So does it require a GPS antenna?
                                  #813115
                                    Excellent stuff … keep-up the great work !
                                    Could you show us the locations of these ‘family’ clocks please?
                                    John Haine
                                      @johnhaine32865
                                      If it only corrects the minutes then GPS is hardly relevant.
                                      #813238
                                      dk0
                                        @dk0
                                        The forked device can correct the error by +/- 1.5 minutes.
                                        Yes, the limits are determined by the fork width.
                                        A pin is mounted to the minute wheel.
                                        The PLC has its own quartz with high accuracy.
                                        #813244
                                        Bazyle
                                          @bazyle
                                          The synchroniser is interesting. Tower clock? Ours takes quite a lot of force to correct but not sure if that is the weight of the hands and gearing or just the friction to lock the arbor and wheel is set high.
                                          #813248
                                            I find it ‘philosophically’ rather pleasing that these magnificent old Tower/Turret Clocks have entered a new chapter in their history.
                                            Once they were cutting-edge ‘Keepers of Time’ and they have gently morphed into well-earned  retirement, as ‘Displayers of Time’
                                            dk0
                                              @dk0
                                              The shaft that transmits the movement to the hands doesn’t require much force to turn because it’s highly geared, and the weight of the hands doesn’t affect it either, as they should be balanced, so I think something’s out of place causing this stiffness.
                                              P.S. Please note that to correct the position of the hands, you need to release a minute indexing device.
                                              #813253
                                              dk0
                                                @dk0
                                                My family produced about 100 tower clocks between 1850 and 1940. At that time, these clocks were located in our region of Emilia Romagna (Bologna).
                                                Of these clocks, 23 are still in working order, they are remotely controlled and I regularly maintain and service them.
                                                20230415_103452
                                                IMG_20220806_110709
                                                20240630_102437
                                                20240327_082118
                                                #813276
                                                  Thank You
                                                  Robert Atkinson 2
                                                    @robertatkinson2
                                                    How does the monkey “know” when to start and stop climbing? Are there limit switches attached to fixed points? Perhaps on a seperate rope.
                                                    #813298
                                                    dk0
                                                      @dk0
                                                      Stop climbing with a microswitch mounted on the weight.
                                                      Start climbing microswitch mounted on the weight and activated by the lower radius of the chain or alternatively, by a timer with programmed descent time.
