That’s an interesting device.
Does that forked device cope with both slowing the minute wheel when the clock is running fast and advancing it when the clock is running slow?
Are the limits on adjustment set by the aperture of the fork?
I assume this requires a pin to be added to the minute wheel?
Does the device have its own GPS-locked internal clock? So does it require a GPS antenna?
The forked device can correct the error by +/- 1.5 minutes.
Yes, the limits are determined by the fork width.
A pin is mounted to the minute wheel.
The PLC has its own quartz with high accuracy.
