The size and shape of drill holes
Home Forums Beginners questions The size and shape of drill holes
Viewing 7 posts - 26 through 32 (of 32 total)
  • #370612
    Ian S C
      @iansc
      When someone asks about tool makers reamers, I pull this out of my album. If you want to ream a hole in brass, or aluminium these made of steel can do the job unhardened.
      Ian S C
      Tool Makers Reamer
        That remains a very useful sketch, Ian yes
        Great to see that the digital version hasn't got grubby and faded with use.
        Dave Martin
          @davemartin29320
          Posted by pgk pgk on 04/09/2018 08:07:27:
          I had need to set some firm but removable pins into my current project. ……If I drill the hole with a bit labelled 5.5mm then overdrill with the same 6.0mm drill bit then i end up with a hole where the 6.0mm silver steel is too tight. – as in it goes in with a gentle tap but is a bugger to pull out……..
          Actually – that sounds you're drilling it perfectly and the dowels are fitting perfectly! Sounds to me like you're getting a vacuum lock. Solution: (i) if the workpiece will stand it, a tiny vent hole all the way through; (ii) a tiny hole through the dowel pin; or (iii) use a removable pin with either a vent flat or a spiral groove (have a look, for example, at the range of removable dowel pins in the MSC/J&L catalogue).
          pgk pgk
            @pgkpgk17461
            A lt of info in this thread, thanks
            Russel: Gotcha re D-bits.. I admit was still thinking in terms of reaming the hole diameter as well as the base.
            Re: Toolmakers reamer. I can see that a ideal for holes in thin sheet or to 'true' up a pilot hole but a single long bevel will tend to push the tool laterally? The principle of a horseshoe nail is a bevel to direct it away from the white line (sensitive hoof layer). Also note that orthopaedic pins have three short bevels to a point and are used to drill the hole. Living bone is quite elastic and that pin will drive straight and the hole be tight enough for the pin to stay held in situ. (note for situations where the bone end it's being buried in isn't firm enough they are also available with a thread behind the point)
            pgk
            #370646
            John Baron
              @johnbaron31275
              Hi Guys,
              At one time I used to use "D" bits to drill 3/32" holes in brass 6" deep. Needs a lot of pecking and blowing out !
              I stopped using a "D" bit as a drill, when Dormer made me a very long 5/64" drill specially for this job. I first drilled the hole with the new drill and then followed with the "D" bit.
              #370660
              IanT
                @iant
                I'm about to make an 8mm D-bit to finish to size a long hole in a part. I've thus far step drilled in from both ends (having very carefully centred the work each time). It's been a long time since I've done anything like this, as I [now] have a good collection of reamers but not as it happened an 8mm one (but several suitable lengths of 8mm silver steel). Anyway – I had a look earlier this week at what the 'Gurus' advise.
                The simplest approach is that from Ian Bradley – who basically advises the 'halving' to be 1/2 Diameter + 5 thou – with the cut-out being 3-4 diameters deep. He advises a 10 degree front and end clearance. His article showed a 'commercial' D-bit that had short 'flats' for side relief, as well as cutting fluid channels provided – but Ian stated that he didn't really see the need for the side relief.
                Emgee – I also looked at the Harman article and his approach was quite a bit more complicated – basically stating that side relief was required and suggesting an eccentric machining method to achieve it. The second part of his article then described a D-bit 'milling' tool (used to make tapered holes) and his logic for a) using an eccentric cutter and b) the angle at which the cutting edge should be made relative to the eccentric made a bit more sense to me (than his D-bit did). So whilst I might use Harmans approach to make a custom tapered milling bit if I ever needed to – I'm going to stick to the Bradley approach for my D-'drill' – although I did briefly think about adding a little (flat) side relief, although I know a D-bit cuts on the front edge.
                Ian Bradley also advises that the D-bit must be withdrawn frequently (to clear debris) and the body must be smooth and kept well lubricated (to ease rubbing). This 8mm one is a bit longer (and larger) than I've tried before, so it will be an interesting exercise. Fingers crossed…
                IanT
                #370684
                  One old design for a drill for accurate holes in hard materials is to put three flats on a rod to give a triangular shape with three short lands. Put a triangular point on the end as a relatively blunt pyramid, and if large enough notch all three cutting edges.
                  I haven't tried this.
