I usually get things right by the second attempt but have, in the past, needed three goes at some things before getting the hang of the machining ‘rules’ for the job! This one went smoothly, as these days I go more slowly and think ahead carefully.
Having multiple chucks around allows me to avoid having to swap out workpieces (from the chuck, at least). This particular job was one of those 🙂 and was fitted in among other on-going work. Three chucks and two mills in operation (not all at the same time!). My first chuck back plate was very pleasing, as I recall, from long ago. Since then, most jobs have been repairs, modifications or making replacement parts – no model engines to be completed or anything like that.
As it was the first tapered pin I had attempted (I don’t particularly relish small fiddly bits and pieces) it was satisfying to get it right as I knew as soon as I fitted the pin to the hole that tapers matched perfectly and my time had been well spent. Any more will be easy as it is always the first one that is most troublesome. Only having the one small tapered reamer (of unknown taper) made it important not to get that part of the job wrong. I may never need to do it again, who knows?
At my age I am quietly satisfied when things go well first time. I neither get euphoric over things nor too P’d off if things donn’t go entirely to plan. I just set to and try to do it better, if things go pear-shaped.
Let’s face it, this little job would have been ‘run of the mill’ for a proper machinist!
