Superglue chucks
Superglue chucks
Home › Forums › Beginners questions › Superglue chucks
  • #10062
    Iain Downs
      @iaindowns78295
      How hot to release?
      #449103
      Iain Downs
        @iaindowns78295
        I've been using superglue wax chucks recently (mainly on the mill) and it works well most of the time.
        The first couple of goes I tapped the piece from the side and it came off nicely. Not happened since.
        Now I use heat. Specifically the oven, but I suspect I'm overdoing it. I've been running the oven at 200+ centigrade which certainly does the trick, but it stinks (and SWMBO isn't keen).
        I'm struggling to work out how hot it should be. I've used a blowtorch and the oven, but suspect I'm overdoing it. I like the idea of the oven (particularly for big parts) as it is more controllable.
        Iain
        #449108
        John Haine
          @johnhaine32865
          Iain, I have been using a related technique for both wood routing and CNC milling recently. Clean the syrfaces, carefully apply a layer of the high quality blue Scotch masking tape to each, making sure there are no overlaps or gaps. Smooth down the tape and get rid of any air bubbles. Then apply dots of superglue to one surface and carefully apply the other on top of it, pressing together until they bond. Once the job is done, with a bit of care you can lever off the cut part with a knife blade inserted between one surface and the tape.
          Now for another suggestion. When I did this recently after I applied the glue I put down the workpiece the wrong way up, so it was glued firmly to the tape! I prised it off but the "top" was covered with hardened glue and torn tape. I stuck it down properly the other way up to do the job but was then faced with removing the mess. So I dropped in into a stainless steel pan, just covered with water, and boiled for a couple of minutes. The glue just slid off leaving a clean surface behind.
          This suggests that 100 C should be plenty hot enough.
          Edited By John Haine on 26/01/2020 20:21:17
          #449142
          Neil Lickfold
            @neillickfold44316
            It depends on the super glue being used. There are higher temp super glues that will hold to about 150 c or so, and others can only hold to 100c to 110c.
            #449146
            not done it yet
              @notdoneityet
              Carry out a simple series of tests to find out (starting at a low temperature, of course)?
              #449307
              Mark Rand
                @markrand96270
                Hit it with a heavier hammer. Use a block of wood between hammer and work to avoid damage, if needed.
                #449413
                Neil Lickfold
                  @neillickfold44316
                  Sometimes freezing can remove super glues as well. Tap it with a piece of wood and hammer while still frozen.
                  It just takes longer unless you have dry ice handy.
                  Edited By Neil Lickfold on 28/01/2020 08:57:44
                  #450070
                  Iain Downs
                    @iaindowns78295
                    The heavier hammer was, naturally, my first thought. But the glue was too strong – or I was too weak.
                    I tried the testing approach, but I'm not sure what my results meant. I started at 110 centigrade and after an hour tried to knock the part off sideways. Didn't move. Then another hour at 140. Also didn't move, but when i lifted it, it came off fairly easily. So 110 might have worked if I'd levered it up.
                    I will however, try the blue scotch masking tape approach which seems to be much less cumbersome – does anyone know if colours other than blue or brands other than scotch will also work? My local B&Q doesn't stock it.
                    Iain
                    #450097
                    not done it yet
                      @notdoneityet
                      Your series of tests (but sadly only 2?) clearly demonstrated the futility of soaking at 200 degrees Celsius?
                      I doubt that anything metallic will need soaking at temperature for an hour to raise i temperature by 30 degrees, as most metals are good conductors of heat and the size is not excessive.
                      Somewhere between 110 and 140 would seem to be adequate. It worked, presumably no stink – so what is the problem?
                      KISS principle; if it works, use it; if it ain’t broke why fix it?
                      They all come to mind.
                      #450173
                      Iain Downs
                        @iaindowns78295
                        Thanks NDY.
                        The time period was mandated more by the lengths of episodes of House than any scientific approach. I've been working on the 1 hour per inch which I've read in this forum when soaking metal.
                        However, it would be nice not to have to wait for an hour or risk the wrath of you know who if there is a smell. So the Blue Scotch Masking tape is an approach I would like to experiment with. Or beige b&q masking tape if anyone thinks that will work.
                        Iain
                        #450175
                        John Baron
                          @johnbaron31275
                          Hi Guys,
                          I've used various methods for sticking items to a wax chuck ! Super glue works well as does double sided tape. I've never had any problem removing parts. A sharp wood chisel works well and easily removes any glue or tape residue.
                          Soft parts like fibre ones, you do have to take a lot more care over removing. It you aren't very careful you can split the material. One dodge that I use with those is to stick a paper backing on first then the part. Hot water will soak off the paper.
                          #450177
                            Unfortunately; this is getting to be like one of those ‘Loctite’ discussions, where the specific product detail has been lost, and so we are guessing.
                            As a broad generalisation ‘Blue’ masking tapes are low-tack, and cleanly removable.
                            This range has some decent product descriptions: **LINK**
                            https://www.decoratingdirect.co.uk/shop/product/search?searchword=kip+masking+tape&page=1
                            As for B&Q own-brand offerings:
                            I suspect that we might be “Spoiling the Ship fo a ha’porth of Tar” … but I haven’t done comparative tests, so I don’t know.
                            John Haine
                              @johnhaine32865
                              My local B&Q stocks the blue Scotch tape – that's where I got it from.
                              not done it yet
                                @notdoneityet
                                Really? Try holding a 75mm length of 25mm aluminium bar, about 50mm from the end, and dip the other in nearly boiling water – and check just how long it takes for your end to get too hot to hold! It will not be two hours!🙂
