super heaters
super heaters
Home Forums Locomotives super heaters
Viewing 25 posts - 1 through 25 (of 26 total)
  • #346452
    Chris Sheward
      @chrissheward84999
      I have been in the process of making coaxial type super heaters x/2 for my 5inch Stirling single. Having 3 times tried to solder (Easyflow 55) the outer stainless steel tube to the copper regulator tubes without success I am now thinking perhaps I`d be better off without super heaters altogether. The tubes are only 10/1/2 inches long are they really going to make that much difference. The steam collector tube high up in the boiler will presumably do an efficient job of producing somewhat dry steam. I would appreciate any members views on this subject. Many thanks
      Chris Sheward
        @chrissheward84999
        stirling single
        #346454
        Speedy Builder5
          @speedybuilder5
          What flux are you using? You need Tenacity Number 5 in my experience for S/steel.
          BobH
          #346475
          Chris Sheward
            @chrissheward84999
            Thanks for that Bob. as far as I am aware the flux we use should be compatible with the grade of silver solder used and not the metals being used, so, one should be able to solder stainless using Silver-flo 55 and using Easy-flo flux. Is it not all to do with the temperature regarding the flux used.
            #346480
            John Olsen
              @johnolsen79199
              The flux has to be active enough to attack the oxide layer on the material, which in the case of stainless means it has to take off the Chromium dioxide layer that forms. Ordinary flux probably will not do this so as Bob said above you need the Tenacity 5
                Posted by Chris Sheward on 17/03/2018 14:22:33:
                No, you need high-temperature fluxes for good results with stainless steel whatever silver solder you use.
                A few here:
                http://www.cupalloys.co.uk/silver-solder-fluxes/
                #346483
                Tim Stevens
                  @timstevens64731
                  The oxides that form on stainless steel when heated are quite different to those on copper or brass, so you should not expect the same flux to work equally well. And its not just the 'high temperature' nature of the flux, but the exact constituents. It can also matter what grade of stainless you are using as although they all contain Chromium and Nickel, other metals are used in the various alloys.
                  Regards, Tim
                  #346490
                  Clive Brown 1
                    @clivebrown1
                    JM market an Easy-Flo stainless steel flux. It's more aggressive than the normal E-F flux to deal with the stainless steel oxide layer, but works at lowish temperatures.
                    #346506
                    duncan webster 1
                      @duncanwebster1
                      to be real;y effective your superheaters shoul pass well into the firbox, and normal out and return version is better as well
                      #346517
                      Martin Johnson 1
                        @martinjohnson1
                        Chris,
                        As noted by others you need a specific flux for stainless, which should make your problems surmountable.
                        As to whether you need superheaters – yes you do. If you look at Bill Hall's tests at:
                        https://www.advanced-steam.org/wp-content/uploads/2017/08/Measuring-Steam-Engine-Performance.pdf
                        Fig. 5 in particular shows that superheat can change the steam demand from the engine over a range of about 2:1. Would you be quite so relaxed about putting in half the grate area, half the tubes and half a firebox? I rather doubt it!
                        Personally, I would not recommend a concentric superheater, but I see the manufacturing simplicity of such a beast. As Duncan says, a good dose of radiant heat from the firebox will also help matters along.
                        Martin
                        #346525
                        Paul Kemp
                          @paulkemp46892
                          Martin,
                          There is no disputing the value of superheating steam. Whether you can actually get any meaningful degree of superheat in a 5" gauge engine is quite another matter. The writer acknowledges his ancient Speedy fails to develop any superheat even when driven hard. I would be surprised if there are many 5" gauge loco's that develop more than a few degrees of superheat let alone the amount required for a noticeable impact on efficiency. Is there any published data for actual superheat achieved for various designs?
                          Paul.
                          #346529
                          Redsetter
                            @redsetter
                            It tends to be forgotten that superheaters only work when they are properly hot and this takes some running time to achieve. I have driven 5 inch gauge locos which are not superheated, and they work perfectly well. Possibly they use more coal and water than their superheated counterparts but this is very difficult to quantify, and so what, anyway? In average start-stop running on a club track I am not convinced that superheating makes much difference.
                            #346536
                            julian atkins
                              @julianatkins58923
                              Hi Chris,
                              I suggest you ditch the coaxial superheaters as they are not very efficient. The LBSC type is far better in copper pipe and spearhead return bends, but the return bends do need to be sifbronzed up to the copper pipe.
                              The coaxial type originated with Don Young's Mountaineer design in ME early 1970s at the suggestion of Alec Farmer.
                              A few years ago I became a convert of stainless radiant stainless superheaters extending into the firebox – that have to be TIG welded at the return ends, and is a job far beyond my capabilities. But friends with the requisite skills or contacts have provided the necessary.
                              I would never build a loco without superheaters in 3.5"g or 5"g. If you are a good attentive driver you notice the difference after the first half lap. The loco is more lively, uses less water and coal, and the valve gear can be notched up further so further using less steam. You also go through a tunnel and spectacle wearers like myself do not get their glasses 'steamed up' preventing seeing signals. The saving of coal and water is quite considerable in my experience.
                              Cheers,
                              Julian
                              #346683
                              David Wasson
                                @davidwasson11489
                                I had a professional TIG weld the spear head of my super heater elements. I did the silver soldering of the elements to the headers. This was a copper to stainless steel joint. I used 45% silver solder and high temp black flux.
                                Do not experiment on your super heater elements to see if you can solder them or not. I made several experiments on test joints to convince myself that I could achieve good penetration between the copper and stainless. The joints were cut to pieces for examination. Only after successful test joints, did I move on to solder my elements to the headers.
                                Yes, I vote for elements that go all the way into the fire box. I also vote for the spearhead type connected together at the "pointy" end by a TIG weld done by someone that knows what they are doing.
                                David
                                Edited By David Wasson on 19/03/2018 01:58:25
                                Edited By David Wasson on 19/03/2018 01:59:15
                                #346685
                                Simon Collier
                                  @simoncollier74340
                                  I totally agree with Julian and David.
                                  You can talk about all the theory in the world or, you can drive a saturated loco, add superheaters, and drive it again. That will be all the convincing you will need. The smaller the loco, the more important superheating, or steam drying if you like, is. The improvement between saturated, and copper elements withing the flues, is greater than the improvement going from copper to radiant stainless elements, but the latter are the best.
                                  #346689
                                  Redsetter
                                    @redsetter
                                    I have in fact driven saturated and superheated locos in broadly similar conditions over many years and I am not convinced either way. As an engineer I think for myself and I take into account all aspects of the problem in hand.
                                    Now the great god julian has spoken and all his sheep bow down to him, instead of having an intelligent discussion. We should be trying to help the OP with his questions. It's all about winning the argument, not solving the problem.
                                    We are only playing with toy trains and anyone who is worried about about fuel and water savings in that situation needs to get a life and get out more. He may enjoy the meetings of the Flat Earth Society, if he isn't already a member.
                                    #346697
                                    David Wasson
                                      @davidwasson11489
                                      Hi Redsetter,
                                      Hmmm…..all his sheep? Wow, I wonder how many there are? The must be herds of them!
                                      Yes, we should help the OP with his question. As I mentioned, I silver soldered my stainless superheater elements to the copper headers with 45% silver solder and high temp black flux.
                                      I think you were pretty distracted and you forgot to answer the OP's original question. Since you seemed to have missed it, I'll restate it, if I understand it: What do you use to silver solder copper to stainless steel? As you are a self proclaimed engineer, I'm sure you will have a helpful and insightful answer.
                                      David
                                      #346702
                                      Anonymous
                                        Posted by David Wasson on 19/03/2018 09:46:33:
                                        That's sheep for you, where there is a small gathering of them more tend to gravitate without asking questions, and before you know it there's a whole herd. smile
                                        #346708
                                          Posted by julian atkins on 17/03/2018 22:18:48:
                                          As a biologist, I'm familiar with the 'counter current multiplier' principle which the Kidneys use to concentrate salts in the kidneys.
                                          The co-axial superheater is an excellent design for concentrating heat at the hot end of a superheater as the wet steam entering at the firebox end cools the superheated steam coming the other way. This means pretty hot steam is entering the return end at the firebox making the end hotter than it needs to be.
                                          I'm sure such superheaters work, but I bet they give less superheat than one with two separate tubes and wouldn't be surprised if they don't last as long either.
                                          <edit> baaa – I have never made a superheater so what would I know?
                                          Edited By Neil Wyatt on 19/03/2018 11:50:48
                                          #346715
                                          David Wasson
                                            @davidwasson11489
                                            Andrew,
                                            You seem a bit distracted by sheep as well as Redsetter. The question remains: How did you silver solder the stainless steel superheater elements to the copper headers in your locomotive?
                                            David
                                            #346717
                                            Another JohnS
                                              @anotherjohns
                                              Chris – the only superheater I've made is to LBSC's design, for Tich.
                                              It was not a success – mainly because the flue it's in got plugged the first day out, and I have not been able to clean it out – 20+ years without it has convinced me that the effort is not worth it. I've tried poking a 1/16th steel rod through, but no luck; the front end and superheater are just too cramped, at least in my build.
                                              Now, I'm certain that a radiant superheater makes a big difference to water and coal consumption, as well as condensate on ones' glasses. It does make you worry about lubrication of cylinders, etc. The Raritan build (CI cylinders and rings) does NOT have a lubricator, so one less part to make or purchase. It is saturated, of course.
                                              I think that what we need is for someone to make 3 or 4 locomotives identical locomotives, with the exception of superheaters and, superheater type. Then a valid comparison can be made. Say, a stud of Simplexes, with:
                                              1) Simplex, no superheater;
                                              2) Simplex, in-flue superheater;
                                              3) Simplex, two-tube radiant superheater;
                                              4) Simplex, coaxial superheater.
                                              And, measurement tools for determining efficiency.
                                              Me? Nope! I'm not going to build them! Life's too short; I've got my Shay (no superheater) to get running when the snow melts, my 2-8-2 (superheater removed by previous owner) to fix some leaking pipework, and get my Ivatt 2-6-0 running, which will be made without superheaters, just to get the thing on the rails. Mind you, I'd love to try all 4 Simplexes (Simplii?) one day, so hopefully someone'll get cracking and churn them out.
                                              A fun and challenging hobby, and I enjoy the individualism shown by all – it would be boring if we all made the same thing, right?
                                              John.
                                              #346744
                                              Steamgeek
                                                @steamgeek
                                                Adding a small amount of common or garden table salt to flux when silver soldering stainless does significantly help the process, irrespective of your personal beliefs of how effective the superheaters / steam dryers are:
                                                #346764
                                                Simon Collier
                                                  @simoncollier74340
                                                  If Redsetter wishes to be offensive, perhaps he might use his real name. No profile either, I note. Julian may not be quite a deity, but he is vastly experienced, and if asked, extremely helpful. I share his enthusiasm for good front end design, superheating, and valve gear that allows one to drive on the reverser.
                                                  Alas, JAS's proposed experiment will never happen. Soon though, I will be able to compare directly a well made saturated Blowfly with a well made one with only two copper elements. I provided the latter's boiler with 2 x 3/4" flues which replaced two 1/2" firetubes. It was run for some months with copper twists in the flues, then the superheaters were added. The difference was amazing.
                                                  It is easy to convince oneself that something doesn't make much difference if you are not willing, or not capable of making it. Hardly an objective opinion. So who here used to superheat their engines and now don't bother because they don't think it makes any difference?
                                                  How you use the engine is important too. Anything will putter round light engine. On the busiest days, our club gives 1000 rides an hour. One Saturday I drove my Simplex with a heavily loaded 6 car train plus guard's van, with a larger engine leading, for over 3 hours without a break. When pulling up the long 1 in 60 you need everything going for you.
                                                  To the OP I would add only that I sand the stainless tube end with wet&dry or similar to take the surface oxide off and instantly paint with HT flux.
                                                  #346808
                                                  duncan webster 1
                                                    @duncanwebster1
                                                    Bill Hall had a Speedy with LBSC type superheaters, he measured the steam temperature entering the cylinders, there was no superheat. He then fitted radiant superhaeters, and had a marked reduction in water consumption, to the extent that he had to sleeve down his water pump. Unfortunately he never repeated the measurement. If you're using less water it's pretty obvious your using less coal. I know coal isn't expensive, but using less can make the difference between having enough steam and not. There was an article in ME a few years back where 2 chaps from Urmston club measured superheat, and there certainly was some (4 Oct 2013)
                                                    as for being one of Juian's sheep, well he's usually on the button, but not as regards having to weld radiant supeheaters. High temperature silver solder or sifbronze works for me The worst conditions for a superheater are during steam test, hot fire and no steam flow. I can't recall anyone's failing after steam test at our club. So a muted bleat from me!
                                                    #347173
                                                    doubletop
                                                      @doubletop
                                                      After I was advised to use the Harris Stay Silv black flux I've never had an issue with silver soldering copper to copper, copper to stainless or stainless to stainless. As part of my rebuild I remade the copper headers for my Dart superheaters that had stainless tubes and spears (not concentric).
                                                      To add to the mix of the discussion one of our club members has been warning about the copper to stainless joints being susceptible to failure. The advice was:
                                                      • Wherever possible avoid a copper to stainless joints.
                                                      • If you have to do copper to stainless ensure adequate overlap of the joint, e.g. a swage the end of the copper tube and insert the stainless tube (or use a smaller bore copper tube that inserts into the ID of the stainless; but why would you?)
                                                      • Never do joint that is a stainless tube into a hole in the side of a copper tube e.g the stainless super heater tube T’d into the copper header cross pipe.
                                                      • Never use a copper and stainless super heater when it is to be upstream of the regulator, which would mean it is always at boiler pressure. Ensure the superheater is after the regulator.
                                                      The reason for these warnings were some failures recently. One was a failure of the stainless superheaters that were T’d into the copper header. Another case, apparently, was a loco with the superheaters ‘upstream’ and the copper stainless joint failed. The fire door was open and hot coals were ejected. Fortunately, the driver wasn’t on the driving seat.
                                                      The upstream/downstream scenario comes about with the use of ball valves as regulators. Something that doesn’t occur with LBSC or Martin Evans designs. I’ve replaced the Stroudley regulator on my Dart with a ball valve but the super heaters are still downstream, but when a ball valve is located in the smokebox it most likely results in the super heaters being upstream of the regulator.
                                                      The industrial engineers no doubt will have something to add….
                                                      Pete
                                                    Home Forums Locomotives Topics
