sun/planet gears
sun/planet gears
Home › Forums › General Questions › sun/planet gears
  • #141097
    peter warner
      @peterwarner63189
      At the risk of looking stupid,how do I calculate the diameter of a gear with the teeth on the inside diameter?I have cut small gears before-where you add 2 to the DP to get the outside diameter of the blank,how does it work when the teeth are on the inside?
      #23083
      peter warner
        @peterwarner63189
        how to calculate diameter
        #141180
        Brian Wood
          @brianwood45127
          Hello Peter,
          Not silly at all. To find inside diameter for the blank, subtract 2 and divide by DP.
          #141222
          Sub Mandrel
            @submandrel
            Brians formula is correct. I'm not sure how you design the cutter profile, however. I do know that you will have to plane the ring gears unless they are very big.
            If it helps, the general principle is to design gears just by drawing the pitch circles (each of which should have a diameter of number of teeth/DP. If designing with a compass or moving circles around in a cad program the pitch circles should be set out so they touch each other with no gaps or overlaps. If doing it the 'scientific way' the centre distance between gears is (teeth in gear 1 + teeth in gear 2)/(2 x DP).
            For sun and planet gears inside an internal ring gear, the PCD of the ring gear is:
            PCD ring gear = PCD sun gear + 2*PCD planet gear = (teeth in sun gear + 2*teeth in planet gear)/DP
            My head hurts now…
            peter warner
              @peterwarner63189
              Thanks Neil,I think I will need to plane the ring gear.
              Pete.
