Also worth checking that the cross head and/or small end of the con rod are not reamed out of square which would throw the big end off to one side.
EDIT I think it uses the same casting as the beam in which case 3/8" at the thick shaft end and 1/4" at the pin end
Edited By JasonB on 02/09/2018 14:04:52
