Mark,There is no great dificulty in doing it yourself, either with a calculator, or if you have digital calipers, you have conversion at the push of a button, its all part of engineering. I,v solved the problem for me, I use both, although most of what I build is my own design.
Welcome to Model Engineering, it's proberbly a good idea to try and learn a bit about imperial measurements, just as I'v had to teach myself metric. If you get into some old stuff, you may find inches, and parts there of match the origional better than the metric, also you are quite likely to find old stocks of metal, maybe salvaged bits, it might be 1/4 inch when you want 6 mm, 1/4" is just a fraction bigger than 6 mm and so on. Ian S C
Edited By Ian S C on 04/02/2013 09:52:30
