steam oil amount for a two cylinder engine with bore 42 mm /60mm stroke
Home Forums General Questions steam oil amount for a two cylinder engine with bore 42 mm /60mm stroke
  • #368744
    Werner Schleidt
      @wernerschleidt45161
      Hello all,
      I have a simple question, when is the amount of oil enough for the lubrication of a 2 cylinder engine.
      There are some indications I know by experience of my 5 inch steam locomotives. I recognize if there is over the day at the chimney a lubrication and then the loco runs good. That equals about in 3 km distance the oiler have to refilled. With this amount the locos runs good. On my merrywheather fireking i changed the amount of oil, the engine runs better now, but I have the feeling it could have more oil. Is there any rule of thumb or only try and error possible
      best regards
      Werner
      Werner Schleidt
        #368759
        Simon Collier
          @simoncollier74340
          It is pretty crude but we just go on the look and feel of the inside of the chimney after running our locos for 10 minutes or so. After swiping my finger inside, I want to see and feel a greasy deposit. If too dry and grey looking, I conclude under oiling. If spewing oil all over the engine and the chimney inside is really wet looking, it is over oiling. Also the rate at which the lubricator tank goes down is a guide. I have no experience of TEs or fire engines but plenty on this forum do. Their long chimneys might confuse matters somewhat.
          #368905
          Werner Schleidt
            Hello Simon,
            many thanks for your reply. I interpret your answer that all is made by experience with simply controling how is the oily surface in the chimney. That is nearly the same what i have done . It seems that i have to live with this kind of procedure.
            best regards
            Werner
            #369434
            Werner Schleidt
              Hello Simon,
              I made after the last run the experience that in the chimney near the top there is inside a greasy film like coal tar.
              The engine runs good now.
              Werner
