Springs for 5 inch bogie
Home › Forums › General Questions › Springs for 5 inch bogie
  • #579248
    Michael Callaghan
      @michaelcallaghan68621
      Hi, anyone out there know who sells springs suitable for the bogies of a 5 inch gauge electric locomotive. I can’t find them anywhere. Thanks michael
      #28507
      Michael Callaghan
        #579285
        noel shelley
          @noelshelley55608
          Maxitrak.com /Maidstone- Engineering.com may be a good starting point or Polly Model Engineering Ltd. Good luck. Noel.
          #579330
          Clive Brown 1
            @clivebrown1
            Reeves 2000 stock a range of springs that can be used for locomotive suspensions.
            #579335
            duncan webster 1
              @duncanwebster1
              If you know what you want try ebay, but you'll need basic dimensions.
              #579351
              Ron Laden
                @ronladen17547
                If you search for die springs on ebay you will find lots of them and a wide range of lengths/diameters, they are cheap to.
                The springs are colour coded for the various strengths but no spec or figures only listed as heavy duty, light duty sort of thing. Its a bit of guess work getting the strength you need but being so cheap I got a couple of each for comparison and trial. I listed them as Blue – Light, Red – Med, Green – Strong, Brown – V Strong. Bear in mind though that die springs are in general strong springs so even the Blue – Light spring is fairly stiff.
                Ron
                Edited By Ron Laden on 09/01/2022 06:46:44
                Edited By Ron Laden on 09/01/2022 06:53:19
                #579432
                Michael Callaghan
                  Thanks chaps
