Speed controller with immersion heater?
Home › Forums › Beginners questions › Speed controller with immersion heater?
  • #362516
    nigel jones 5
      @nigeljones5
      Help sought. I have a tank in my workshop – nothing to do with the domestic water supply – with a standard type immersion heater fitted. I want to be able to finely adjust the temperature of the water and wondered if simply plugging it into a 4kw 240v variable speed control unit would work, the type that are advertised for controlling fand and dimmer switches? The heater has an adjustable thermostat but its not designed for constant adjustment.
      #9258
      nigel jones 5
        @nigeljones5
        #362522
        David George 1
          @davidgeorge1
          You need a proportional temperature controller you need to look up on line as there are many suppliers. As you set temp a thermocouple measures temp and switched power as necessary.
          David
          #362523
          John Rudd
            @johnrudd16576
            You would be better off using a PID temperature controller with a thermistor to provide feedback of the water temp…..( you might not need the Derivative function…wink    )
            A speed controller is just open loop…..
            Edited By John Rudd on 16/07/2018 21:10:47
            Edited By John Rudd on 16/07/2018 21:14:19
            #362524
            Emgee
              @emgee
              Hi Fizzy
              I agree the thermostats fitted to immersion heaters may be a bit coarse for some applications but they do seem to be consistent in switching temperature.
              For finer control you will need to fit an electronic probe and control that will switch the element on for short periods until the set temperature is attained. Positioning the probe is important but it is unlikely to achieve all water at the same temperature if you don't have positive means of circulating it in the tank.
              By whichever electrical method used for heating the water temperature will be controlled by a thermostat or similar device, even your variable speed control unit.
              Emgee
              #362525
              John Rudd
                @johnrudd16576
                Posted by Emgee on 16/07/2018 21:09:48:
                Hi Fizzy
                Emgee
                Err…how does the speed control know what the temperature is with no feedback?
                #362529
                Emgee
                  @emgee
                  Posted by John Rudd on 16/07/2018 21:13:00:
                  Hi Fizzy
                  Emgee
                  John, I suggested a thermostat but your guess is as good as mine for such an application.
                  Emgee
                  Edited By Emgee on 16/07/2018 21:32:17
                  Edited By Emgee on 16/07/2018 21:33:28
                  #362533
                  John Rudd
                    @johnrudd16576
                    Emgee, as an Instrument Engineer, mine is not a guess…40 years plus served in industry…I dont offer advice lightly..
                    #362540
                    Emgee
                      @emgee
                      Posted by John Rudd on 16/07/2018 21:57:23:
                      John, I had already suggested a method of control, almost the same as your suggestion but I did add a circulator would be required to ensure even water temperature in the tank.
                      To use a motor speed controller is a no go as suggested by my reply, but it would heat the water by switching the supply on, just add a stat as 2 wire on/off control cct.
                      Emgee
                      #362564
                      nigel jones 5
                        @nigeljones5
                        thanks all
