Softening epoxy
Softening epoxy
Home Forums General Questions Softening epoxy
  • #813731
    old mart
      @oldmart
      Acetone does attack epoxy to some extent, we had tanks of acetone to rinse off Skydrol hydraulic fluid used in civil airliners because it is non flammable. The rinsing had to be fast as the eoxy paint finishes would suffer if exposed to the acetone for more than a few seconds. We had to test various hydraulic sub assemblies including shimmy dampers and they were always contaminated externally with the Skydrol (phosphate ester) which would not be safe to handle without being rinsed off before final inspection and packaging. You wouldn’t want to get any in your eyes, it hurts.
      michael howarth 1
        @michaelhowarth1
        I had a tube of epoxy that went hard, took it back to the shop, he exchanged it quite happily but told me to microwave the dodgy tube – it worked a treat.
        Mick
        #813791
        John Haine
          @johnhaine32865
          Hmm – in my case the tubes are metal so microwave wouldn’t work!  Anyway this is a brass block with epoxy (Araldite?) that has cured over 30+ years.
          It has sat in a jam-jar of acetone since last Wednesday with no sign of softening, so I think I will be making a new block.  I have a brass bar end which has one hiding inside…
          #813834
          old mart
            @oldmart
            Bad luck with the acetone, MEK is hard to get now as it is harmful to the ozone layer. It’s amazing what lurks inside a block of metal when you have the machinery dig it out. What about simply running a milling cutter straight through the leds and glue to remove them?
            #813861
            KEITH BEAUMONT
              @keithbeaumont45476
              O;d Mart,
              Your saying you had tanks of acetone,as a rinse,”because it is non flammable” does not sound right to me,  Acetone is very flammable.
              Keith.
