Small machining opportunity
Home Forums General Questions Small machining opportunity
  • #470381
    Robert Johns 1
      @robertjohns1
      Is there anybody who can assist me in completing a bit of accurate machining with the use of a small lathe?
      The component in question is a standard Compression Tap connector, which requires the end machines down to a size for fitting a o-ring to.
      Component and drawing supplied, just require price for the actual machining.
      Robert Johns 1
        @robertjohns1
        One off modification to brass fitting
        #470440
        Pete.
          @pete-2
          You might be better off saying what you're willing to pay rather than asking a price, as someone might quote machinist rates that would exceed the value of what you have in mind.
          A location also, as posting back and forth will cost.
          #470748
          Simon Werner
            @simonwerner38477
            Call your local machinist
