Small grinding wheels for toolpost grinders
Home › Forums › Workshop Tools and Tooling › Small grinding wheels for toolpost grinders
  • #440332
    William Girvan
      @williamgirvan78218
      Hi,
      Can anyone recommend a UK supplier of small grinding wheels (with mandrel) for use on a toolpost grinder ?
      I've been searching in vain for wheels of around 2" in diameter. There seems to be very little available between Dremel-type tools of max 25mm and bench grinder wheels of 100mm and above.
      #19552
      William Girvan
        @williamgirvan78218
        Suppliers for small grinding wheels for Toolpost grinders
        #440354
        Mark Simpson 1
          @marksimpson1
          I've had good service from midland abrasives (recommended on here by someone) when trying to get some smaller wheels for my tool/cutter grinder…
          http://www.midlandabrasives.com
          You can get cylindrical "mounted points" up to about 40mm diameter
          They also had knowledgable human beings on the phone when I rang them
          Good Luck
          #440359
          William Girvan
            @williamgirvan78218
            Thank you very much for this information. I will take a look at Midland Abrasives.
            #440363
            Phil P
              @philp
