Slotting a change wheel bore
Home Forums Beginners questions Slotting a change wheel bore
  • #270653
    Andrew Tinsley
      @andrewtinsley63637
      Going through an old cupboard, I found a rusty heap of change wheels. It is an odd collection as nowheel has the number of teeth on it, but for example 9-10 mm.
      They are the same tooth size as Myfords and also thickness ties up. The bore is considerably smaller than the Myford bore.
      I was thinking of boring them to Myford size and using them. The only snag is the keyway. How do you do this with the limited range of tools that I have at present. Basically an ML10 and most of the attachments for an ML7. I can think of ways to do the job but not with the kit I have available.
      I did come across a slotting device which can be made (this one for an ML7). However I have no idea where I saw it. Can anyone help? I wouldn't mind making one up, I do miss my big power shaper!
      Andrew.
      #8427
      Andrew Tinsley
        @andrewtinsley63637
        #270657
        John Rudd
          @johnrudd16576
          College Engineering do a casting for a slotting tool….if that helps? ( I happen to have one, its on my roundtoit list..)
          #270659
          Jon Gibbs
            @jongibbs59756
            Ian Bradley's book has several ideas but perhaps the most useful is based around the topslide without the feedscrew. The topslide is operated by a long lever…
            #270661
            Simon Williams 3
              @simonwilliams3
              Andrew – whereabouts are you? I'm in West Gloucestershire and there is a slotter in my shed. Alternatively if you bore them and post them to me I'll slot the keyway and post them back Best Pm me if you're interested rgds Simon
              #270664
              not done it yet
                @notdoneityet
                Handraulic shaper tool in the toolpost?
                Cut a square hole in position before boring? (See Clickspring video for making one).
                Pin the gears together with a pegs until such time as you can do the keyways
                U-toob might be your friend for ideas and demos.  Here is one example:  https://youtu.be/yQcgLDZLMsk
                Edited By not done it yet on 08/12/2016 15:21:25
                #270672
                John Haine
                  @johnhaine32865
                  I had a similar problem to make a keyway in a bushing I made for a pulley when fitting 3-phase motor to my VMB. The bushing us loctited into the large bore of what was the intermediate pulley and fits the 3/4 shaft of the motor. (The pulley normally has two large ball races and runs on a stud.) I turned and bored the bush in mild steel, and at the same setting locked the headstock and mounted my 5/8 boring bar which has a dedicated mounting block on the topslide, replacing the normal Dickson holder. I made an HSS tool bit to a sort of parting profile and fitted it to the end of the boring bar at centre height, but at 90 degrees to normal orientation. Then used the rack to move the tool back and forth to cut, applying feed from the crosslide. It took a while but did the job without needing to make any special tooling (other than the cutting bit). I must have been lucky profiling the tool as the slot needed almost no fettling to fit the key.
                  #270684
                  Clive Foster
                    @clivefoster55965
                    If you have swiss or similar small files the easiest way is to drill a hole slightly smaller than the desired keyway size in the correct position before boring out. Generally the centre of the drilled hole will co-incide with the edge of the bored hole leaving an essentially semi-circular cut out. Its pretty easy to file the hole out to size so its a snug fit on the key. If you want a real nice job and have HSS blanks the right size its not too difficult to make up a sharp tool which, when set-up with its centre line on axis, will shave out the last couple or three thou to give a truely fitting keyway.
                    I got a bunch of standard gears from HPC to make an imperial conversion set for my metric Smart & Brown 1024 and put off doing them for a year or so as I never seemed to get round to making a slotting device. Eventually I had to do one "right now" for an urgent job. Drilling and filing proved to be so easy that I did them all "right now" before getting on with the urgent job. Unless you have other work for it making a slotting device for this job is a waste of time. I used a diamond file set that came as a freebie from ArcEurotrade several years back to square out the holes.
                    Might be worth making a guide bushing for drilling accurately. I didn't bother. Just set a pin sized to be a nice fit in the original bore vertical in the drill vice, dropped the gear over and had at it with a smart new drill.
                    Clive.
                    #270687
                    Ajohnw
                      @ajohnw51620
                      The design for the casting College Engineering sell works well. The centre height comes out correct for myford 7's. I use one on a Boxford but it needed packing up on a spacer. The fact that they match the centre height of the lathe is a good idea really. Some make things up to fit in a toolpost. The principle is the same on most of them really. A shaft that fits nicely in a hole on centre with the lathe and a lever arrangement that stops it rotating and provides the cutting force that is needed.
                      Using the rack feed etc on the lathe to do it can be a very bad idea – something is likely to break.
                      Can't find a photo of the one based on the casting as lots of people fabricate them. Few shots here
                      Also some on youtube.
                        You can use a boring bar in the toolpost with a bit set sideways on and just plane it out using the carrage handwheel taking a thou at a time.
                        Did these 3/16" wide ones that are 1" long in steel that way
                        Can even just do it with a HSS bit in the toolpost
                        #270694
                        Ajohnw
                          @ajohnw51620
                          surprise I reckon the gear that ran along the rack on my Raglan was broke doing it that way Jason. I've heard from others at times that have had this experience.
                          Maybe this is one up for China and down for Myford and Raglan.
                            Think I did those steel ones on my Emco 8.6, the ali one is the Warco. I have broaches now so don't do it as much
                            #270699
                            Michael Cox 1
                              @michaelcox1
                              I do not know the size of gear or slot you are talking about but I have used a very simple adjustable broach to make slots for pulley and gear. More details are here:
                              http://mikesworkshop.weebly.com/small-hole-slotting-tool.html
                              #270736
                              Andrew Tinsley
                                @andrewtinsley63637
                                Thanks everyone for your help, Why is it that I can't think of even the simple answers like the drilled hole, bore and then use a swiss file on the half moon left? I fear that I don't have the muscles left to do a lot of filing!
                                Simon, many thanks for your kind offer, I live in Rutland so I fear it would be a postal job! I would prefer to make up a slotting tool , because A/ it will expand my number of tools and B/ it will give me much needed experience as a retread.
                                So it looks like a toss up between the Ian Bradley slotter and that from Mikes Workshop, oh and the College Engineering casting set.
                                Which of the many Ian Bradley books is this described in? I have a few of them and maybe this is where I saw the design.
                                #270744
                                John Stevenson 1
                                  @johnstevenson1
                                  Andrew,
                                  I'm over on the Notts Derby border NG10 post code so not that far away if you want to pop over and I can broach they whilst you wait, only a 10 minute job.to do the lot.
                                  #270745
                                  Gray62
                                    @gray62
                                    Just to throw another design into the mix is this keyway slotting tool from Hemingway
                                    Not cheap but if anything like other kits I have had from them, excellent quality with good drawings/instructions
                                    #270767
                                    Thor 🇳🇴
                                      @thor
                                      Andrew,
                                      I made a slotting attachment for my lathe some years ago and have used that to make keyways when needed. It bolts to the cross slide instead of the topslide.
                                      Thor
                                      #270770
                                      Hopper
                                        @hopper
                                        I cut a 5/32" keyway in a bored out 60T cast iron early Myford change gear using the same method as Jason, just hold a boring bar in the tool post with tool bit set "sideways" and rack it back and forth with the carriage handwheel. I did this on my old Drummond M Type when making the worm wheel for the GHT dividing head.
                                        It works, but is slow. I think if I were doing a full set of change wheels, I'd look at making one of the simple slotting attachments. Maybe one as suggested I think by LH Sparey that uses a long lever pivoted on the rear tool post, and attached to the main tool post, with the topslide leadscrew removed.  But if you do one or two gears a day for a week or two, you will get there the slow way.
                                        Edited By Hopper on 09/12/2016 08:05:05
                                        #270789
                                        Ajohnw
                                          @ajohnw51620
                                          Maybe Neil will throw up a freebee. The design that uses the College Engineering Casting was in MEW Aug/Sept 1991. The casting doesn't look much different to the one I have which I thought was much earlier.
                                          The basic idea is that when the base has been machined the bore for the ram can be done by mounting the casting on the cross slide. That way it's exactly on centre and it's possible to slot keyways that will have a very sexy fit pretty easily. The problem with the hole and file idea is getting the hole on a true radial position. The keyway usually finishes up somewhat wider than needed, width depending on the skill of the person that does it.
                                          blush I used mine to gash an RMS thread tap. Fine for that bit getting a sharp edge after screw cutting it needed some delicate dremel grinding. In the end I bought one but it worked well in brass.
                                          not done it yet
                                            @notdoneityet
                                            Ajohnw,
                                            You are right about the LJ Raglan. I would not use mine like that unless there was no other possible option, or the materials were relatively easy to cut. The 5" would be far more robust in this area and may well cope with care. Options
                                            suggested are not necessarily appliccable to all kit and the OP needs to take things into account, for his machine.
                                            #270808
                                            Clive Foster
                                              @clivefoster55965
                                              I wouldn't claim to be a filing expert but I had no trouble doing sufficiently good keyways in my change wheels for threading duties. Helps that the Smart & Brown uses a small key and relatively thin changewheels. Be different if taking real power or cutting large keyways. If I ever do a metric set for my Pratt & Whitney Model B I will be sorting out a bit of mechanical help.
                                              Even if you have a slotting head putting a drill in first makes the job a lot easier as the drill takes most of the metal out. If you don't have a slotting head and don't see enough work in future for making one to be worth the time and effort Jason's second picture is probably best approach to final finishing after opeing the drilled hole very close to size with a file. I'd probably have done mine that way if I'd had a suitable piece of tool steel in stock. Drilling first also reduces the load on a broach if you have a set.
                                              Clive.
                                              #270816
                                              Ajohnw
                                                @ajohnw51620
                                                I was interested to see that MEW had done a project based on a casting. If no one does they will disappear off the market. Many things have. With something like a slotting attachment a casting makes some sense as metal is in the places where it will be needed. Fabrication some times takes more time and may turn out to be only a little cheaper or even more expensive. In this case the casting is likely to save on time. I don't think that is always the case though.
                                                One idea Neil might like to think about is making an index of MEW available and allowing people to buy specific design articles rather than subscribe. I'd guess that there are a number of people who don't see getting the magazine every month of interest as much of the content wouldn't be relevant. The ones that could be bought could be arranged to be rather old ones so if anyone want's anything from say the last 5 years or more they would have to subscribe.
                                                Edited By Ajohnw on 09/12/2016 11:36:21
                                                #270928
                                                Hopper
                                                  @hopper
                                                  Posted by Clive Foster on 09/12/2016 11:15:38:
                                                  Yes, it pays to bear in mind that change gears are a low-speed, low-power application so keyways do not need to be a super precision job. Even if they turn out a bit of a loose fit, the slack in the gear train is taken up as soon as the tool starts to cut and so is consistent, regardless of clearances between gear teeth or keys.
                                                  On my old Drummond the changegears are not keyed but paired with taper dowel pins that are a press fit in one gear but stick into a clearance hole in t'other with 10 thou or so clearance, so there is all kinds of operating slop but they have been cutting threads for 80 years or so without problem.
                                                  It's a different situation if for instance you are cutting a keyway in a dividing head gear train as I was. In that case you need precision location for most foolproof action so a machined keyway will be best. Ditto for say a motorbike crankshaft key that is to handle 20-100 horsepower etc. Any slop there would result in failure.
                                                  #270945
                                                  Brian H
                                                    @brianh50089
                                                    Another way of slotting that is usually overlooked these days is to chisel them. As an apprentice in a company making large stationary and marine diesels, there were a few jobs that it was not feasible to put on a machine and so the keyways were chiselled. With care it was surprising how accurate and quick this could be.
                                                    #271293
                                                    Howard Lewis
                                                      @howardlewis46836
                                                      I made a Slotting Attachment using the College Engineering Supply casting. (It came with a reprint of the article by, the now late, Peter Robinson. He was a member of the Peterborough Society of Model Engineers)
                                                      Once the base had been machined, mounting it on the Cross Slide of the Myford, allowed the bore for the Ram to be machined. When the Myford was sold, made a riser block to adapt it to my BL12/24.
                                                      When a one off square socket (for a speedo drive adaptor for a scooter) was needed urgently, the tool was gripped, axially, in a collet, in the Tailstock and racked too and fro using the Tailstock Handwheel, with the Tailstock clamped to the bed. Progress was slow, each axial cut was only about 0.010" deep, rotating the chuck holding the workpiece 90 degrees for each cut. It took time, but eventually produced the required square hole 1/2" deep.
                                                      So, if you are wary of filing the keyway, that is another possibility. But putting on the cut using the Cross Slide (as already suggested) would be my preferred method.
