Simple collet chuck removal tool
Home › Forums › Workshop Tools and Tooling › Simple collet chuck removal tool
  • #362071
    Thaddeus Swarfburn III
      @thaddeusswarfburniii
      I have a collet chuck for my Emco Compact 8 and use a homemade drawbar to keep it tight. Unfortunately the only way to remove it is to loosen the drawbar and rap on it with a hammer, which is not doing the bearings any favours. I had thought about making a threaded ejector on the outboard end but the spindle holeis 20.5mm, which is not a convenient size to tap. I decided to attack it from the other end. Made a prototype out of PVC pipe and it works so well I don't think I'll bother making it out of metal.
      Pics in gallery:
        #362079
        BW
          @bw
          Thanks Thaddeus,
          Thats terrific – have never seen that before. Nice piece of thinking. I will copy that idea right now this afternoon in 5 minutes.
          Bill
          #362080
          not done it yet
            @notdoneityet
            Looks good. Anything, which makes the extraction more controllable, is better than thrashing with a hammer.
            I hope you were not using a steel faced hammer – a copper or lead mallet will load the bearings but not damage them like a hard faced hammer which considerably increases the impulse force transmitted through the bearing contact surfaces.
            I use wedges similar to those marketed by ArcEuroTrade (but mine are home-made) and suitable spacers to remove tight MT tapers. Also works well.
            #362085
            Joseph Noci 1
              @josephnoci1
              Now THAT's thinking out the box! Very smart indeed!
              Joe
