Sharpening drills
Sharpening drills
Home › Forums › Beginners questions › Sharpening drills
  • #58579
    Wolfie
      @wolfie
      OK can anyone tell me how to rescue blunt drills?
      #5286
      Wolfie
        @wolfie
        #58603
        Digger
          @digger
          I have a fixture from draper that allows you to set the angle of the rake for the drill and then you use it against the bench grinder to get a good edge. You can try to re grind a drill by the “Rack of the eye” method but you need a steady hand, it’s okay to use that method if need a drill right there and then but it won’t really be accurate. The draper fixture is okay and not too expensive and will give a good result once you’ve got used to using it.
          #58607
          John Shepherd
            @johnshepherd38883
            Wolfie
            Have a look at this current  thread on ‘advice on drill sharpening jigs’
            Edited By John Shepherd 1 on 11/11/2010 11:09:07
