Nearly a year later I think that I have solved the problem with this steam engine……..or more accurately I have found a way round the self starting difficulties if the motor stops with the cylinders at BTC and TDC.
This involves the use of a needle roller one way clutch bearing which is fitted on the crankshaft. I have made up a collar with a drop link, which is a close fit over the bearing. The second item required is a miniature push pull solenoid. This is linked to the drop arm of the bearing collar. On application of 12 volts, the solenoid, which has a movement of 10mm, pulls the crankshaft round approximately 50 degrees which is enough to enable self starting when the steam is turned on. With the motor running the crankshaft turns freely inside the bearing. The solenoid and bearing came to about £6 and in this case was money well spent. The requirement for a battery is no problem because the boat needs one anyway for remote control.
If this is of any use to anyone else please feel free to PM me for details.
Mick
