Searching forums and albums
Home Forums General Questions Searching forums and albums
  • #660345
    David-Clark 1
      @david-clark1
      Hi All.
      How do I search albums on this forum, posts as well.
      I did quite a few post's, photos and articles many years ago but can’t see how to find them.
      One of interest is the article I wrote about fitting a chuck to a backplate.
      My user name back then was David Clark 1 but I don’t have access to the hobby store email for that account so can’t log in. Suggestions are welcome.
      #29380
      David-Clark 1
        @david-clark1
        Where are my online posts?
        #660347
        Stuart Smith 5
          @stuartsmith5
          David
          Is the article on the backplate?
          I did a search using the search box near the bottom of the home page.
          I searched for ‘David Clark 1 backplate’ and this came up.
          or this one: ‘David Clark 1 album’
          https://www.model-engineer.co.uk/albums/member_albums.asp?c=42726
          Stuart
          Edited By Stuart Smith 5 on 17/09/2023 10:26:39
          #660348
          Ady1
            @ady1
            It can be a bit convoluted in here
            I try and find specifics via google on the ME home page
            and use any thread post for posts and piccies
            Edited By Ady1 on 17/09/2023 10:38:17
            #660350
            David-Clark 1
              @david-clark1
              Thank you Stuart, that is the one I was looking for.
              #660351
              David-Clark 1
                @david-clark1
                Actually, there should be an article on drilling 24 holes in the face of the backplate, I could do with a copy of this article. I think it had a listing of the program I used. I could do with this listing for my new (to me) CNC mill.
                #660353
                David-Clark 1
                  @david-clark1
                  Hi Stuart
                  I searched using the google search at the top of the home page but nothing was found. I can’t see a search box lower down the page.
                  #660354
                    The forum doesn't help much with searching.
                    The 'Search This Site' box top-right looks for basic word matches in Post Titles. Not wonderful.
                    Much better is the Google Search hidden away half-way down the home page.
                    Also possible to to search the forum directly with advanced search syntax in your browser. For example:
                    SillyOldDuffer site:model-engineer.co.uk causes your internet search engine to only return hits from model-engineer.co.uk The syntax is standard, works for me with DuckDuckGo, should also be good with Google, Bing and the other usual suspects. By default albums are created 'Public', and there's no need to login to explore them.
                    Be quick! The forum is about to be replaced, maybe next month. Images in an album that aren't referenced by a post will be lost.
                    Stuart Smith 5
                      @stuartsmith5
                      David
                      The Google search box is near the bottom of the home page
                      Stuart
                      #660360
                      David-Clark 1
                        @david-clark1
                        Thank you Stuart, I found it now. I was not on the home page.
                        Silly old differ. “Be quick! The forum is about to be replaced, maybe next month. Images in an album that aren't referenced by a post will be lost.”
                        Is the forum being replaced completely? It has always been quirky, probably because it was custom built.
                        It would be a shame to lose all this knowledge, almost 20 years with. I hope it will be accesible in the future, to valuable to be lost. I found the CNC drilling article I wanted. Thank you all for your help.
                        #660368
                          All old posts will be brough forward, just new software and format
                          #660370
                          Ady1
                            @ady1
                            Posted by David-Clark 1 on 17/09/2023 11:59:47:
                            The Yahoo farce lost millions of hours of useful human knowledge, this place is just a blip in comparison
                            Once they trash Wikipedia there won't be a decent useful repository of human knowledge on the entire internet
                            Times they are a-changing
                            #660371
                            David-Clark 1
                              @david-clark1
                              OK, I hope it works OK, I have reservations.
                              #660372
                                You are not alone crying
                                #660373
                                David-Clark 1
                                  @david-clark1
                                  I had reservations back when the forum was started. I believe as editor of the magazines I was the first member other than the site designer. He built the whole thing from scratch, hence the difficulty of not being able to modify it to overcome problems.
                                  #660390
                                  Martin Connelly
                                    @martinconnelly55370
                                    If I was going to drill 24 holes in the face of a backplate I would set the x and y zero on the centre of the backplate then after drilling the first hole use G68 to rotate the coordinate system 15°, drill the next hole, rotate another 15° and repeat until 24 holes have been drilled.
                                    (set up for first hole)
                                    (code to drill hole)
                                    G68 A0 B0 R15
                                    G68 A0 B0 R30
                                    etc
                                    Martin C
                                    #660393
                                      I'd just let F360 write the code after clicking one hole. But it all comes down to what you have so marking out using a Myford Bull gear and compromised indent may have to do.
                                      #660641
                                        The new forum software works, but there are still lots of wrinkles to iron out…
                                        David-Clark 1
                                          @david-clark1
                                          Hi Neil
                                          Same place I was back circa 2006.
                                          Jason, I think a Myford Bull wheel is 65 teeth. Not ideal for dividing.
                                          #660670
                                            Some are 60 depending on the model I believe, if not stick a change wheel on the far end of the spindle.
                                            Not sure about wrinkles, more like hills and valleyssad
