screw type abbreviation
Home › Forums › Beginners questions › screw type abbreviation
  • #453993
    gerry madden
      @gerrymadden53711
      I have an assembly drawing that calls up a couple of countersink head screws, eg. 1/4BSFx1/2 which is then followed by the suffix 'ASH'. Can anyone tell me what the suffix means ?
      Gerry
      #10091
      gerry madden
        @gerrymadden53711
        #453994
          "Allen Socket Head" would be a possibility.
          #454283
          Howard Lewis
            @howardlewis46836
            BSF = British Standard Fine
            BSW = British Standard Whitworth.
            BSP = British Standard Pipe
            BA = British Association
            UNF = Unified National Fine
            UNC = Unified National Coarse
            UNEF = Unified National Extra Fine.
            NTP = National Taper Pipe
            Whitworth form (and BSF and BSP &nbsp threads are 55 degree while Unified form are 60 degree angle. BA form are 47.5 degree angle. Metric are 60 degree form.
            BSW and UNC thread pitches are often the same, as are many BSF and UNF, but DO check! BSP and NTP are different thread form, and the TPI varies as well.
            Metric threads are defined by diameter and pitch, so that you can have the standard Metric Coarse, say 12 x 1.75 and a fine version as 12 x1.5 or even finer at 12 x 1.25.
            There is no reason why diameter and pitch cannot be non standard. Some Myford lathes used 7/8 x 12 tpi, while then later ones used 1 1/8 x 12 tpi. This is quite common practice for screw fitting chucks for lathes.
            Allen Socket Head screws are often referred to as Capscrews. Csk signifies Countersunk head.And then there are Button head and Dome head varieties as well!
            HTH
            #454284
            Steviegtr
              @steviegtr
              Also BSB
              British Standard Brass. Not sure if it's the same as BSP.
              Isn't there more as well. CEI cycle thread ???
              Steve.
              Edited By Steviegtr on 25/02/2020 18:08:22
              #454286
              Howard Lewis
                @howardlewis46836
                British Standard Brass is a Whit form thread but with a constant 26 tpi.
                Cycle Thread is also 26 tpi, but is 60 degree thread form, so not really interchangeable.
                The other variations on the Whitworth thread form are the Model Engineer threads. Most are a constant 40 tpi, while others are 32 tpi.
                #454289
                  Gerry was asking about the suffix (bit at the end) "ASH" not the actual thread form abbreviation (BSF etc).
                  Edited By JasonB on 25/02/2020 18:28:39
                  #454307
                  old mart
                    @oldmart
                    Cycle threads, that is BSCy come in a large variety of pitches, not just 26tpi. Motalia have a number of thread charts within their site:
                    https://www.motalia.co.uk/
                    Edited By old mart on 25/02/2020 20:03:28
                    #454311
                    Tony Pratt 1
                      @tonypratt1
                      'ASH' sounds like a non standard call out just to confuse every one, who's drawing is it?
                      Tony
                      #454319
                      Dalboy
                        @dalboy
                        I also would go with Jason,s explanation. I know I am mainly woodworking but I have spent 25+ years in plant repairs dealing with many types of fittings.
                        #454320
                        Georgineer
                          @georgineer
                          Posted by Howard Lewis on 25/02/2020 17:58:13
                          A lot of people think so, but this is from an American source:
                          " Some confusion over the UN designation exists. Some people think it means Unified National based on the fact that three national entities came together to unify their thread standards; thus: Unified National Screw Thread Form. By reading the [standard] B1.1 this is not supported; rather UN is the abbreviation for UNIFIED."
                          I think the 'National' is a hang-over from the American National series of threads, which was replaced by the Unified Thread Series in 1949.
                          BSC (sometimes called BSCy) replaced CEI threads (Cycle Engineers' Institute) in 1950.
                          British Standard Brass thread is not a British Standard…
                          George
                          #454321
                          not done it yet
                            @notdoneityet
                            I expect it will be like these.
                            Likely fewer available, rather than buying that many, from other suppliers
                            #454325
                            Steviegtr
                              @steviegtr
                              Dad worked at the British screw company, later to be GKN. Guest , Keene & Nettlefold if I have spelt it right. Anyway he always said it was United Nations fine course etc.
                              Steve.
                              #454326
                              gerry madden
                                @gerrymadden53711
                                JB and NDIY, looks like you were bang-on. When I looked carefully at the dwg it was a socket head type. Thank you for the confirmation.
                                Gerry
