Sandown Exhibition
Sandown Exhibition
Home › Forums › Beginners questions › Sandown Exhibition
  • #5370
    A Smith
      @asmith78105
      Myford Imperial/Metric changeover system
      #62958
      A Smith
        @asmith78105
        At the Sandown Exhibition, someone (possibly a SMEE member)was demonstrating a Myford with an extra banjo in the changewheel train. This allowed easy changeover between metric and imperial by operating a simple dog clutch. The banjo casting and an extended changewheel cover are available from this Gent. Does anyone have a contact address? I seem to lost the note that I made at the time.
        Really enjoyed the show, by the way.
        Regards.
        Edited By A Smith on 22/01/2011 10:57:24
        #62963
        John Stevenson 1
          @johnstevenson1
          The gent in question is D.A.G. Brown, a member of SMEE, sorry no contact address for him.
          You can also achieve the same thing a lot easier by just swapping the input driver for the standard 24 tooth to either a 33 or 34 tooth and use the normal gearbox ratios.
          There is a slight error this way but not enough to affect anything but leadscrews and NASA related threads. These same tow gears will also do BA threads down to 6BA.
          There is often someone on Ebay selling these two gears together with a laminated chart showing the gearbox ratio to select.
          For most uses this is a better way than the Myford way of buying a new banjo and gears for metric as you do not have to swap everything over and you still have access to the power feed.
          John S.
          #62993
          A Smith
            @asmith78105
            Thanks for the info and for the alternative suggestion, I’ll look into that.
            #63009
            DMB
              @dmb
              John Stevenson,
              I am also interested in finding items referred to on ebay, have tried, no luck. Can you please suggest search word(s)?
              Thanks,
              John C.
              #63023
              KWIL
                @kwil
                A Smith, read your PM.
                #63047
                DMB
                  @dmb
                  Hi John S.,
                  John, Thanks for info – v. useful + would never have found it without help.
                  John C.
                  Edited By David Clark 1 on 24/01/2011 11:02:58
                  #63048
                  David Clark 13
                    @davidclark13
                    Hi There
                    Search for user
                    marypoppinsbag
                    on ebay for metric gear details.
                    I think they also do useful dividing plates and back issues of ME and MEW.
                    regards David
