Rubber mat.
Rubber mat.
Home Forums Workshop Tools and Tooling Rubber mat.
Viewing 25 posts - 1 through 25 (of 31 total)
  • #504651
    David Colwill
      @davidcolwill19261
      Over the last couple of years I seem to have started to feel the cold a little more. This is particularly bad when my feet get cold.
      I bough a rubber mat off ebay for £21.99. It is 5 foot by 3 foot and about 3/8" thick. The sides are bevelled and and it has holes that allow oils swarf and finished components to fall in to.
      It has made a huge difference to working on the lathe and I have now ordered another for in front of the bench.
      There are a number of people selling these and I have no connection with any of them.
      Regards.
      David.
      David Colwill
        @davidcolwill19261
        Hardly a workshop tool but….
        #504660
        Mike Hurley
          @mikehurley60381
          Yes, we all start to feel the cold as we get older… I tend to find that any kind of mat / carpet can sometimes be a bit of a nuisance by moving slightly or creasing up and me tripping on the bits that subsequently stick up.
          I made up a couple of lengths of wooden 'duck boards' – simply long strips about 30mm wide nailed onto occasional cross pieces, with about a 25 mm gap between each. They keep your feet off the cold concrete, let metal turnings drop through easily and are easily lifted to find that vital last screw you just dropped (or simply to clean).
          Just my personal preference, but obviously whatever suits the individual. is fine. Mike
          #504667
          Bazyle
            @bazyle
            You had a 5ft x 3ft clear floor space in your workshop !!!!! Do they sell 18" x 2ft pieces?
            #504670
            Jouke van der Veen
              @joukevanderveen72935
              I suppose you can cut it?
              #504671
              Speedy Builder5
                @speedybuilder5
                I use old carpet, beside the lathe I have a floor mat, probably ex Sketchly office services which served as the door mat to a company, tapered rubber edges (Non trip) and some sort of man made fibre carpet. My Dad's workshop had 1/2" ply boards over concrete. The boards were originally used as sacrificial boards under alloy sheets which were routed out for aircraft panels.
                #504673
                Alistair Robertson 1
                  @alistairrobertson1
                  I bought a couple 600 x 900 mats from BigDUG **LINK**
                  They wanted to charge £15 delivery but I objected as the charge did not show until checkout so I got free delivery!
                  They are very good mats and perfect for a workshop.
                  #504678
                  David Colwill
                    @davidcolwill19261
                    Posted by Bazyle on 01/11/2020 11:28:53:
                    Damn it! I must have been burgled. smile p
                    Alistair.
                    I looked at the smaller mats but they were nearly as much as the larger ones (on ebay at least).
                    Jouke van der Veen.
                    I will probably get another and cut it in half as this seems to be cheaper than buying smaller ones.
                    David.
                    #504684
                    Paul Lousick
                      @paullousick59116
                      Try your local hardware store. If like the ones here in Australia they sell a number of rubber mats of various cut sizes and on a roll and sold by the metre. Insulation from the cold is not as big a problem here but is good to stand on and prevent aching feet from standing on a hard floor.  I also have a 6' x 4' x 1/2" piece on the floor of my car trailer to cushion the load.
                      Paul.
                      Edited By Paul Lousick on 01/11/2020 12:16:08
                      #504690
                      HOWARDT
                        @howardt
                        I use foam rubber mats from Halfords, and other places. Pack of six, I think 600mm square, link together with edge pieces, £10 the set. Used them both in the shed on wood floor and garage on concrete, been down four years and still good, insulate well.
                        #504691
                        Nick Clarke 3
                          @nickclarke3
                          Posted by HOWARDT on 01/11/2020 12:28:37:
                          plus 1
                          #504692
                          not done it yet
                            @notdoneityet
                            We have had this sort of thing for over 25 years, at least. No idea where the roll came from, back then. My ex installed a strip in the bathroom and I later used the rest in front of my workbench and lathe.🙂
                            #504713
                            Circlip
                              @circlip
                              2" x 3/4" laths spaced to suit on 3" x 1" battens, make whatever size you want.
                              Regards Ian.
                              #504719
                              duncan webster 1
                                @duncanwebster1
                                When I converted my garage I had the floor covered with mastic asphalt to get it level and waterproof, then 25mm polystyrene covered with flooring grade chip board, all topped off with the old vinyl flooring from the kitchen. Only downside is you have to cut holes and fit packers under machine feet, but I don't move the machines around very often.
                                #504720
                                Brian H
                                  @brianh50089
                                  I used some of the rubber tiles sold for garages and gyms etc, that interlock together. Not expensive.
                                  #504729
                                  Zan
                                    @zan
                                    I have several of these. one is about worn out after 10 years
                                    yes they do cut, and are brilliant for
                                    1 collecting swarf so it doesn’t get embedded into shoes
                                    2keeping feet warmer
                                    3 stopping small parts dropped getting lost, they lodge in the holes
                                    #504730
                                    Ady1
                                      @ady1
                                      Solid concrete garage floor so a pair of old knackered hillwalking boots, so a comfy fit, and double socks
                                      A fleece beanie helps too
                                      And I'm a bad boy but I use leather working gloves too, those yellow things, they make a huge difference when the temp starts heading towards zero, otherwise the cold metal sucks the heat right out of your hands
                                      Means I can work in comfort all winter, my hands are clean and I really can't remember the last time I had to dig out a bit of swarf
                                      Edited By Ady1 on 01/11/2020 15:46:53
                                      #504735
                                      Steve Withnell
                                        @stevewithnell34426
                                        I just use a couple of layers of carpet offcut…
                                        #504740
                                        Chris Evans 6
                                          @chrisevans6
                                          Posted by Nick Clarke 3 on 01/11/2020 12:32:45:
                                          plus 1
                                          Plus 2 I have covered my entire double garage floor with them.
                                          #504746
                                          larry phelan 1
                                            @larryphelan1
                                            Been using homemade duckboards for years,, cheap simple, and they really work ! What more could you want ?
                                            #504756
                                            Martin Kyte
                                              @martinkyte99762
                                              I have flooring grade tongue and groove chipboard on top of underlay on a concrete base. Works very well.
                                              regards Martin
                                              #504757
                                              Emgee
                                                @emgee
                                                My workshop floor is 6" of concrete and I use re-cycled 1/2" thick rubber conveyor belting which does for the mill and workbench, I use thick rubber mats at the lathes.
                                                Emgee
                                                #504925
                                                mechman48
                                                  @mechman48
                                                  plus 1
                                                  +2 , still going well after 4 years; have spread & puckered up in a couple of places so will trim.. eventually.
                                                  George.
                                                  #504938
                                                  Trevor Crossman 1
                                                    @trevorcrossman1
                                                    Posted by mechman48 on 02/11/2020 16:47:00:
                                                    George.
                                                    Make that +3, these foam linked squares have proved to be a great covering over my concrete floor for the past few years and have saved several carefully machined parts from damage when they've slipped through oily fingers! The only downside that I've noticed is that if I drop a small item, my less than perfect hearing doesn't detect where it fell and the said item will tend to bounce away into some hidden corner.
                                                    Trevor
                                                    #504967
                                                    Henry Brown
                                                      @henrybrown95529
                                                      I used to have those linked square mats but they don't like weld splatter! I was given some heavy ribbed rubber matting from a horse box, its about 15mm thick and tough as old boots, the ribbing helps with insulation of course.
