Rough Milling
Rough Milling
Home Forums Beginners questions Rough Milling
Viewing 25 posts - 1 through 25 (of 60 total)
  • #95416
    Wolfie
      @wolfie
      I am getting some really poor finishes with my milling machine. What are the possible causes??
      Seems to differ by direction, ie across or back and front traverse.
      Its almost knurled in some cases, I can drag a fingernail over it and feel the cuts. Looks a bit like a ploughed field on places too.
      I'll get some pics tomorrow.
      #6269
      Wolfie
        @wolfie
        #95418
          Most likely … the head is not exactly perpendicular to the table.
          Time for some careful "tramming" to see what you have.
          Nobby
            @nobby
            Check end mill or slot drill to see if the ends are ground ok lay on a flat surface to see it the cutters are ground correct ie sharp with correct clearance As M G says check to see if the head is square using dti etc .Or slower feed with coolant would help. A good indication if the heads out of square if the cutter trails on the back end when cutting . But you know that already
            Nobby
            #95430
            _Paul_
              @_paul_
              What are you cutting? & what are you cutting it with?
              Paul
              #95431
              Ady1
                @ady1
                Have you done any milling on your lathe?
                See how much difference you get when you have a high stiffness lathe, use the same cutters on the same materials
                Any vibration is fatal for milling
                Speed isn't always best, sometime backgear is miles better because of heat and vibration issues
                I got fed up trying, milling was too much of a wing and a prayer, not a pleasure
                So I bought a small shaper
                #95436
                Harold Hall 1
                  @haroldhall1
                  I am reluctant to contribute to this thread as I feel it can only be covered if answered in depth, still here are a few pointers. First I like Ady's idea, as a control systems engineer solving a problem by a process of elimination is a good approach.
                  Michael is quite correct in suggesting that the spindle not being perpendicular to the machines table. However, I question the word “exactly” as a very slight error can work to ones benefit. I think it was Tubal Cain who recommended when setting up the Dore Westbury milling machine that there should be a very slight error.
                  If we consider a cut being taken to machine a surface, then inevitably one edge of the cutter will be lower than the other. Even the standards laid down for industrial machines allow this to be the case.
                  If the cut is being taken such that the leading edge is the highest then when the already machined surface reaches the rear edge this will also be attempting to make a cut, known as back cutting. There is though a major difference, the leading edge will be cutting on the outer diameter whilst the trailing edge the end of the end mill. More importantly, it will be at a very shallow angle to the surface resulting in a width of cut being much greater than that taken by the leading edge but extremely thin.
                  Unless the cutting edges are razor sharp then this will not be possible and the cutter will only bounce off the surface. As I often say, you cannot take a cut of 0.001mm deep if the edge has a radius on it of 0.002mm. As the workpiece is fed further the depth of cut being called for will increase and eventually the cutter will break through the surface causing a ring to appear. This is why keeping the end cutting edges of an end mill sharp is much more important than the outer diameter edges where surface finish is concerned.
                  If then the workpiece is fed the other way the trailing edge will be higher and back cutting will, in theory, be eliminated and a much better surface finish achieved. Whilst this is largely true another factor kicks in, that is vibration. As Ady states this is a major factor as whilst the trailing edge is in theory higher, the machine head bouncing up and down will allow the cutter to contact the surface occasionally. The finish will still be far superior to that when fed in the other direction.
                  If, and that is a big IF, the head is set exactly perpendicular, vibration will result in back cutting in either direction, albeit less than my first example but significantly worse than the second. This I think shows that a small error, as permitted by the machine standards, gives you a choice.
                  Our knowledgeable moderator, David, once told me that he used to put a little tweak in his CNC programming to eliminate back cutting, showing that perpendicular errors are still present in industrial machines. Vibration, whilst not totally eliminated, would be much less a factor I would have thought.
                  There is of course the situation where rather than the front and trailing edges being at differing heights, it is the two sides of the cutter. This results in a saw tooth surface but I think I have said enough.
                  If you go to my website, look in the new site index under T and find” Tramming and the effect on finish achieved” there is much more detail on the subject.
                  Of course, material spec, speed and feed are also important factors.
                  I wish I had room for a shaper Ady, lucky you.
                  Harold
                  #95441
                  MICHAEL WILLIAMS
                    @michaelwilliams41215
                    Hi Wolfie ,
                    Most likely causes :
                    Blunt cutter .
                    Excessive cut or feed rate .
                    Slack in any of column fixing / slides / head / spindle / collet / quill / chuck .
                    The orbital patterns which you describe seem to suggest either the blunt cutter or the slackness . Most common problem on these milling machines is that the milling spindle is orbiting either due to slackness or poor bearings.
                    Misaligned slides don't cause the orbital patterns you describe – they just caused crooked work and misaligned successive cuts .
                    Show me some good pictures of the workpiece and cutter end and describe the sounds made when cutting . With that information it should be possible to analyse problem completely .
                    This class of problem was discussed fairly extensively in earlier postings . The earlier postings also explained the causes and effects of cutter vibration .
                    Regards ,
                    Michael Williams .
                    #95444
                      Posted by MICHAEL WILLIAMS on 31/07/2012 10:27:19:
                      Regards ,
                      Michael Williams .
                      … Just like the ploughed field that Wolfie mentioned in his original post !!
                        Posted by Harold Hall 1 on 31/07/2012 09:13:53:
                        < etc. >
                        Harold,
                        A very interesting analysis … with much food for thought.
                        I am intrigued by the suggestion of deliberately misaligning the head:
                        Effectively this is a work-around for the many forms of backlash and flexure in the system. But presumably this would also require one to always cut in one direction ?
                        Grateful for your further comment on this point.
                        David Clark 13
                          @davidclark13
                          Hi There
                          I always biased the head to the right by a tenth of a thou or so over about 8inches.
                          About 4 inches either side of the head.
                          left tenth low —————— Head ——————– Right tenth high
                          Facing the machine from the front and standing at right hand side of machine winding work away from you.
                          This way the cutter cut on the way through and took a tiny skim on the second side of the cutter.
                          You only need to go through in one direction on the final cut.
                          regards David
                          Edited By David Clark 1 on 31/07/2012 16:01:35
                          #95453
                          Ketan Swali
                            @ketanswali79440
                            Wolfie,
                            I think you have a mini-mill.
                            If so, have you checked to see if the locking nuts at the top of your spindle have worked their way loose?
                            Just a suggestion.
                            Ketan at ARC.
                            #95456
                              David,
                              It's good to see the relevant numbers; thank you.
                              I suspect that Wolfie would be very happy if he could set his machine to +/- a tenth of a thou over eight inches.
                              David Clark 13
                                @davidclark13
                                Hi There
                                It is not that difficult with a decent clock.
                                regards David
                                Edited By David Clark 1 on 31/07/2012 17:10:11
                                #95460
                                  Posted by David Clark 1 on 31/07/2012 17:09:54:
                                  … and a robust, high precision mill.
                                  Sub Mandrel
                                    @submandrel
                                    Its a ten-minute job for me to set my mill to inside a thou over eight inches!
                                    colin hawes
                                      @colinhawes85982
                                      Note that excessive tilting bias to cut on one edge of an endmilling cutter will produce an elliptical face.A very small amount as has been recommended can give a better finish. A rough finish is usually caused by a blunt cutter or too loose a fit in one or more slides, possibly due to variation in their fit. Colin
                                      #95466
                                      ChrisH
                                        @chrish
                                        Neil – how do you set your mill up so precisely so quickly? The only way I can see of doing my mill is by checking the quill via a clock against the table at four points roughly the same distance apart as the holding down points and then by adding/subtracting shims under the four column holding down bolts. Am I doing it wrong? I'm very much on a learning curve with my mill! I have a Warco 'Economy' mill, a round column job.
                                        Chris
                                        Edited By ChrisH on 31/07/2012 18:44:19
                                        #95474
                                        Wolfie
                                          @wolfie
                                          OK so let me summarise.
                                          The possible causes are as follows…
                                          The mill head is out either left or right. Its possible, but folks will remember that this is the machine whose lower half dropped off a bench onto a concrete floor and it was substantially checked over at the time by a member of my SME.
                                          The mill head is out back to front. Possible. I did check this especially as I noticed one of the gib strip grub screws was loose. This was also checked at the time of the accident.
                                          The slides are out/loose. Also possible after the accident, these were only checked as far as putting a clock into the chuck and running the mill table back and forth. Was OK. How would I check this more?
                                          The cutters are blunt. Also possible. I bought a set from Clarke for what I thought was an expensive £70 some. This was however 3-16mm both endmills and slot mills so maybe cheaper than I thought. I do note that they seem to have a curious semicircular nick in the end of the blade. Some have it on all 4 and others on only one or two. I get the problem with every cutter though so either they are all blunt…..
                                          And for that matter I know very little about them, what constitutes a blunt endmill?? Especially in the hands of a novice.
                                          There is no doubt in my mind that this mill hasn't cut as well since the bottom half (base, slides and upright) acidentally rolled off my workbench when I was trying to replace the depth stop of all things. It dropped onto a concrete floor and I was somewhat surprised that I hadn't at least bent the leadscrews or something! It has been thoroughly checked for accuracy since then and appears OK but as I said theres no doubt that its not cutting as well as it did before that sad
                                          I'm getting to the point where I'd pay to have it checked out by an expert but as they all appear to be down south I don't know of anybody remotely locally. Grrr.
                                          I'm in the position of having a lathe thats probably older than I am which is superb (and British) and a mill thats barely 6 months old which is giving me problems. Lack of space and cash is my restriction before anyone offers me a Bridgeport smile p
                                          #95475
                                          Wolfie
                                            @wolfie
                                            I'll get some photos tomorrow
                                            #95491
                                              By your description of the cutters they are blunt. before delving further into the machine get yourself a decent cutter and try a cut with that.
                                              If you are getting burrs at the sides and ends of the cut this is another indication of a blunt cutter, sharp ones will leave almost no burr.
                                              J
                                              #95502
                                              Harold Hall 1
                                                @haroldhall1
                                                Sorry Michael for being a little slow in replying, yesterday was a special day out, wife's birthday.
                                                I realise now that I should have quantified the amount I was considering when suggesting that the machine would benefit from the the head being at a minute angle to the tables surface (even that is a debatable comment, more later)
                                                The standard for a new industrial machine is for the permitted error to be no more than 0.025mm over 300mm and I was not expecting a machine to be set greater than this but perhaps approaching the value.
                                                For some reason though, I do not think I have ever seen mentioned the other, and equally important, aspect of a milling machine. That is, how parallel the work table is to its traverse. Again, the standards allow for the table to raise by 0.025mm when being traversed through 300mm. From this it can be seen that even if the spindle is perfectly perpendicular to the tables surface it can still be off perpendicular to the surface of the workpiece being machined.
                                                Perhaps the justification for this features low profile, is that it is one part of the machine that the manufacture finds it easy to better the standard. However, I am not sure about this when the machines come, as most do these days, from the far east.
                                                I am reluctant to go into much more detail here and would suggest the reader visits my website where there are examples of cuts being taken moving left to right and right to left, both with sharp and blunt cutters.
                                                Briefly, Photo 6, with a sharp cutter, shows that for run of the mill tasks traversing either way would most likely be acceptable. What is initially surprising though is that on the left, with the trailing edge of the cutter high, there are still signs of back cutting but very much less than for that on the right. This of course is due to the machines head bouncing up and down and my machine is one of the heavier mill drills so with lighter weight machines the effect is likely to be greater.
                                                Had the machine's spindle been perfectly perpendicular then there would be more evidence of back cutting on the left and less on the right. Of course they would both be the same.
                                                I should add that my machine is just inside the laid down standards left to right and just outside front to back.
                                                For me, both directions would be acceptable for the majority of tasks but where finish is of greater importance, and the workpiece permits it, I have the option of the better finish. This being a better finish than would be achievable with the head perpendicular.
                                                Photo 7 shows again that even with a blunt cutter that on the left is better than that on the right. Had the head been perfectly perpendicular that on the left would have more evidence of back cutting. This showing that in this situation the machine will be more susceptible to the cutter becoming blunt.
                                                Incidentally, the two photographs clearly indicate the burrs that Jason wrote about.
                                                Harold
                                                #95504
                                                  Harold,
                                                  Thank you for the detailed follow-up … and my belated Birthday wishes to Mrs Hall.
                                                  I read your web article this morning, and would recommend it to everyone who is following this thread.
                                                  MICHAEL WILLIAMS
                                                    When milling with an endmill the whole stack up of cutter , chuck , quill , head and column are all twisting away from the cut . In a normal set up most of the deflection occurs in two places – in the cutter/chuck/spindle and separately in the slack of the quill in its housing .
                                                    It is the variable effects of this deflection that cause back cutting and excess rib marks in adjacent cuts .
                                                    On a quality machine like a Hauser the cut marks are absolutely flat and regular and this is because great pains have been taken to make the whole set up rigid .
                                                    Michael Williams
                                                    #95513
                                                    Steve Garnett
                                                      @stevegarnett62550
                                                      Posted by MICHAEL WILLIAMS on 01/08/2012 14:31:41:
                                                      Absolutely. On both mills at work, it's the norm to lock the quills before taking any cuts at all, unless movement of them is absolutely required (rare). Also, every 6 months or so I check the preload on the spindle bearings, and also the lubrication. Since I've been doing this, the surface finish quality of cuts has improved no end.
