Definitely well worth doing. However, there are a few problems with the drawings and part numbers in the article.
I have since found that the useless oil nipple on the rear bearing housing wasn't letting any oil through. I have replaced this with a brass oil cup that really does let the oil get through to the bearings.
Here is what I found. (I think it was later published in MEW.)
I have just completed the mods to my Myford S7 Headstock as described in Ken
Wilson's Article in the April 2011 Model Engineers Workshop.
I have never been able to get this machine to run on the top speed range or to
get the rear bearings to properly adjust to take end thrust when drilling with large
drills. This is in complete contrast to my previous, earlier S7, which spent most of
its life running at top speed with no trouble. Now I can run at top speed – I have
even tried it at twice top speed as I have a 3-phase motor fitted driven from an
invertor to give speed control.
However, I think that there are problems with the dimensions given for the
modifications to the two locking rings and the new spacer. The recess depth,
given as 3.4 – 3.5 mm (0.134" – 0.138" in understandable units) is not deep
enough to clear the inner race of the new bearings. I had to increase the depth to
0.140" to just clear the inner race – 0.144" would be better. It's very frustrating to
discover this when you have got the headstock in bits and no way to remachine
the rings! Fortunately, I had opted to buy new rings from Myford – the part
number is G2340 not G2430 as quoted in the article, order that part number and
you will get a driver plate – so I was able to put the headstock back together and
take the extra few thousandths off.
Having gone to the trouble to make a new spacer to the dimensions given in the
article, I found that with it fitted the front locking ring protruded too far into the
headstock while the rear one was so far into the housing that the C-spanner
could not get hold of the slots. So I put the old spacer back and everything was
OK.
It's definitely worth doing the mods as it now runs faster and quieter and is much
easier to adjust than with the standard ball races.
Dick G
