Right hand engine leads ?
Home › Forums › Beginners questions › Right hand engine leads ?
  • #63389
    Dave Bond
      @davebond87219
      I am building a 5” sweet pea and on the plans it says the
      right hand engine leads. I understand
      this to be the typical arrangement for UK locomotives. When quartering the wheels I take this to mean when the loco is going forward the
      right hand crank pin is in front the left hand crank pin by 90 degrees. So when pushed along the bench the right hand
      crank pin will be at the top of the wheel then still going forward the left
      hand crank pin will be in the same place a quarter of a turn later?>>
      #5391
      Dave Bond
        @davebond87219
        #63402
        mgj
          @mgj
          Yes.
          If you use the 1/4 method used in Jack Bucklers Sweet Pea book, and you use the chuck end of the lathe as the left hand side, looking from the rear of the loco, then you will get the right hand engnine leading by 90deg all built in automatically.
          I’m about halfway through Metre Maid.
          #64017
          Marius pieterse
            @mariuspieterse74678
            where can I get a set of planes for the sweet pea
            #64018
            Marius pieterse
