Reverse Dovetail Milling cutters
Home Forums General Questions Reverse Dovetail Milling cutters
  • #117073
    Clive Hartland
      @clivehartland94829
      I have been trying to purchase a reverse dovetail milling cutter but cannot find any of about 15mm diameter.
      Do any members have a suggestion?
      Clive Hartland
        @clivehartland94829
        #117075
        Sub Mandrel
          @submandrel
          Do you mean a bevel cutter? Or a standard dovetail cutter (biggest at the far end?)
          Mine is about 3/4" / 19mmdiameter – from Tracy Tools – is that too big for your needs?
          M0BND
            @m0bnd
            Try this ….. http://www.mscdirect.co.uk and search for Inverted Dovetail
            Andy.
            Edited By M0BND on 16/04/2013 21:58:32
            #117077
            M0BND
              @m0bnd
              Oops, has that displayed ok?
              Andy.
              #117078
                Andy,
                No … definitey not displaying O.K.
                Can you please insert your hyperlinks using the icon on the toolbar of the message editor.
                Thanks
                Edit: Your shortened version displays O.K.  but it's still a risky way of posting.
                … There are numerous threads on this site about this problem.
                Edited By Michael Gilligan on 16/04/2013 22:06:13
                #117079
                M0BND
                  @m0bnd
                  Posted by Michael Gilligan on 16/04/2013 22:02:02:
                  Andy,
                  Thanks
                  I have deleted and just inserted the site and what I searched for now….
                  Andy.
                  #117080
                  Clive Hartland
                    @clivehartland94829
                    Yes, a bevel cutter 45 Deg would be fine. Correctly called, 'Inverted dove tail cutter'
                    mscdirect, the prices make my eyes hurt !!
                    I did have one but it has dissapeared. A very desirable item and I am sure someone has filched it.
                    Clive    There is one on Ebay but is needing bidding for.
                    Edited By Clive Hartland on 16/04/2013 22:04:55
                    #117083
                      Posted by M0BND on 16/04/2013 22:03:19
                      Andy.
                      Cheers, Andy
                      [Please see my edited post, above]
                      Edited By Michael Gilligan on 16/04/2013 22:09:10
                      #117084
                      Clive Hartland
                        @clivehartland94829
                        I will try Tracy tools again, As you say European tool firms will have them. I will try Brutsch|Ruegger.
                        #117086
                          Clive,
                          Here is one in 13mm … but I see what you mean about eye-watering prices.
                          Note to self: take good care of your Dovetail Cutters !!!
                          JohnF
                            @johnf59703
                            Hi Clive, Depends how much work you need to do but why not make one from silver steel?
                            I have made several over the years, not reverse ones, but no reason why not. Mine were small ones to machine dovetails for rifle/pistol sights and quite small diameter, about 6mm O/D. They worked very well providing you keep the cutting speed at a suitable level for carbon tools.
                            Regards John.
                            #117110
                            John Haine
                              @johnhaine32865
                              What's the application? For chamfering Ali I find that a standard countersink works very well, even making quite aggressive cuts. I think with slow feed and light cut it would do mild steel ok too.
                              #117114
                              I.M. OUTAHERE
                                @i-m-outahere
                                Hi Clive ,
                                Type inverted dovetail cutter into Ebay  (search the world option) and you may see what you want and also try countersink cutter.
                                It depends on what you want it for – if it is a true dovetail shape you need then the countersink cutter won't do as it has a shoulder above the cutting teeth but if it is to cut a bevel then maybe it could work.
                                Ian
                                Edited By SLOTDRILLER on 17/04/2013 06:59:28
                                #117124
                                John McNamara
                                  @johnmcnamara74883
                                  Hi Clive
                                  Google the following:
                                  Inverted dovetail cutter images
                                  or
                                  Inverted dovetail cutter images .uk
                                  One of the better Google secrets for finding things.
                                  Just click on the images not all will link but many do.
                                  It beats trawling through websites.
                                  Cheers John
                                  #117134
                                  KWIL
                                    @kwil
                                    Not a problem, Sussex Tools have all sizes metric and imperial, usually british made. 16mm available. Just a satisfied customer.
                                    #117138
                                    Clive Hartland
                                      @clivehartland94829
                                      Thank you lads, I have now ordered one from Kwils information.
                                      #117169
                                      Sub Mandrel
                                        @submandrel
                                        Well I learned something today (alongside "don't drive over bricks in the road&quot
