Removing a sight glass
Home Forums Beginners questions Removing a sight glass
  • This topic has 3 replies, 3 voices, and was last updated 6 May 2019 at 20:38 by Martin Connelly.
  • #9654
    AdrianR
      @adrianr18614
      #407913
      AdrianR
        @adrianr18614
        Before I start attacking the sight glass with force I thought I would ask here.
        I have a leak from the head stock sight glass on my BH600. The Grizzly manual for the same type of lathe says to remove the sight glass to do an oil change.
        The sight glass is completely round with no visible sign of o-ring or thread. I am sure it must be easy an easy trick to it. Any ideas?
        Adrian
        Edited By AdrianR on 06/05/2019 08:13:11
        #407999
        David George 1
          @davidgeorge1
          Hi Adrian have you called Warco as no one seems to reply with your problem leak I don't know as I have never seen one of these lathes.
          David
          #408007
          Martin Connelly
            @martinconnelly55370
            Hoses Direct sell these as push in polyamide items for tanks with wall thickness of 5mm minimum. Diameter 24mm or 30mm. Really cheap so I don't imagine the Chinese lathe manufacturers would use anything different. Try tapping out from inside the gearbox with a suitable sized socket as a drift.
            Martin C.
