Reaming cylinder bore
Home › Forums › Beginners questions › Reaming cylinder bore
  • #62981
    david newman 9
      @davidnewman9
      I am building a Stuart Victoria, would it be OK to ream the 1 inch bore in the cylinder as I have a Dormer 1 inch hand reamer (new) or should I bore it to size ? David
      #5371
      david newman 9
        @davidnewman9
        #62983
          Seeing as you will have to bore it to a few thou less before reaming you may as well go the whole way and bore it, will be a better job.
          As you get close to finished size make sure your boring bar is sharp and let the tool run through the bore several times at the same setting to work out any spring in the tool.
          Jason
          Edited By JasonB on 22/01/2011 19:57:48
          #63006
          Ian S C
            @iansc
            David, I would’nt recomend reaming a clinder bore, bore it tosay .ooi” from size then lap , reaming leaves the posibility of longitudinal corrigations. Ian S C
