Reamer Identification
Home › Forums › Workshop Tools and Tooling › Reamer Identification
  • #288908
    Manofkent
      @manofkent
      Hello.
      I wonder if any of you clever people can help me. I have a box of reamers which were from another model engineer. However the sizes are not all obviously marked but there are other markings.
      I wondered if anyone knew if there was a way (other than measuring them) to identify the sizes.
      For example – a reamer I measure to be 0.278 inches (7.07mm) is marked:
      T.62992
      79005
      RST TOOLS
      Another is a Dormer C4?
      Marked T37725
      P/N59164
      RST TOOLS
      On this one the reamer is exactly 0.150 inches 3.78mm – could be 3.7725mm I suppose like the marking? (the shank is 0.250 inches).
      They are all marked "RST TOOLS".
      I guess they could be specially made items, but it would be nice to know if the numbering helps.
      Many thanks in advance
      john
      #18453
      Manofkent
        @manofkent
        #288913
        Circlip
          @circlip
          Would question where he got them from. "T" designations suggest they could have been "Specials" made for a manufacturing company.
          Regards Ian.
          #289119
          Manofkent
            @manofkent
            Thanks Ian.
            yes I guess they are specials – I think I have come up against some of these before from a diemaker in the car industry.
            I am sure some are for a types of fit – so for example one is 14 thou less than 0.25 – and 14 thou is the interference fit at that size. (Usually I would make the hole standard and put the fit on the shaft, but I guess it works the other way as well..)
            Dusty
              @dusty
              I fear that 14thou interference fit on .250 would require the services of a 100 ton press .0014 would be nearer the mark is that what you meant.
              #289124
              Enough!
                @enough
                Posted by John Hilton on 16/03/2017 16:13:30:
                Really?
                #289127
                Manofkent
                  @manofkent
                  Hi Dusty.
                  Yup. Cock up on the zeros. Thanks
