Rare Parkson CNC conversion
Home › Forums › Work In Progress and completed items › Rare Parkson CNC conversion
  • #553919
    Yuri Gajdosik
      @yurigajdosik17546
      Recently I have bought a Parkson CNC milling machine, and I'm converting it to run it from MACH3 and also on single phase as I do not have 3 phase in my workshop, also the original machine had the electronics cabinet at the back of the machine which is not very good place as you can't put the machine agains the wall, so I took the cabinet down, made it smaller and it will go somewhere next to the machine. Pictures will follow.
      #31372
      Yuri Gajdosik
        @yurigajdosik17546
        Changing old CNC controls to MACH3
        #554003
        Ian Johnson 1
          @ianjohnson1
          Looking forward to seeing the pictures Yuri, my KX1 runs on Mach3 and I would like to try Mach4, so it will be interesting to see how you convert your machine to Mach3.
          Any reason why you didn't go for Mach4? I only ask because Mach3 is no longer supported by new fangled solutions.
          IanJ
