Precision division plates
Home Forums The Tea Room Precision division plates
Viewing 3 posts - 51 through 53 (of 53 total)
  • #401026
      Posted by Andrew Johnston on 10/03/2019 10:39:22:
      Posted by Michael Gilligan on 10/03/2019 10:32:54:
      RJ Newbould made some very interesting contributions to the Pactical Machinist forum
      Indeed; it happens to us all eventually, but still a great shame. His posts were always a pleasure to read, informative, helpful and polite.
      Just for info.
      Trying to follow-up on the RJ Newbould references
      [see also: **LINK**
      https://www.model-engineer.co.uk/forums/postings.asp?th=109149&p=2
      I drew a blank on the Smithsonian pages. …
      So, I wrote to them asking about the 'Basic Mechanisms' collection. and received to following reply from Jennifer Gloede, Outreach & Collections Specialist, National Numismatic Collection
      [quote]
      Thank you for your email. Many objects in the engineering collection can be found here:
      http://americanhistory.si.edu/collections/subjects/engineering-building-and-architecture
      The Newbould devices are not yet online but should be available later this year when more of the museum's collection is published online.
      [/quote]
      Edited By Michael Gilligan on 18/03/2019 15:30:30
      Anonymous
        Posted by AdrianR on 18/03/2019 15:09:44:
        It uses a Hirth coupling. It was cut not using any bevel so only the outer edge makes contact.
        In #54 Scribe a line there is further discussion about setting the correct angle to cut teeth that mesh properly.
        Err, in which case it wasn't a Hirth coupling but simply a radial spline. By definition a Hirth coupling uses tapered teeth that mate over the full length. The scribe a Line in #54 describes the mathematics to make a Hirth coupling.
        #401055
          Re-reading 'Scribe a Line' in MEW #54, I noticed mention of Voith
          … Their portfolio is impressive: **LINK**
          http://voith.com/corp-en/hirth-couplings/hirth-rings.html
