Please help lost Pultra part
Home › Forums › General Questions › Please help lost Pultra part
  • #575947
    Dell
      @dell
      Hi all
      some how I have managed to miss lay ( or lost ) a bracket from the quick close on my Pultra 17/70, has anyone got a 17/50 or 17/70 with quick close that could give me the dimensions of the part that the quick close handle fixes on then fixes onto back of headstock with two pins, I have the pins , I could probably work out overall size but the gap in between the two pin holes would be a problem, the item is a square U shape with two holes on either side.
      Many thanks in advance Dell
      #28471
      Dell
        @dell
        #575965
        Colin D
          @colind
          I only have one of the 17 series with the lever headstock, and suspect it's different to yours, but I'll go have a look this morning.
          Colin
          #576012
          Dell
            @dell
            Old man with brain fade found it , was still hanging on the painting trestle at work, panic over but thanks for looking Colin
            Dell
            #576017
            Colin D
              @colind
              No problem, i was just going to post this, mine is quite different, and all the rest of my 17 series have just the usual screw drawbars.
              #576056
              Dell
                @dell
                Yours does look very similar to my one at bottom of your picture but it looks like yours has nuts and bolts but my one has two pins.
                Dell
