plastic caged roller bearings
Home › Forums › Workshop Techniques › plastic caged roller bearings
  • #212954
    gary
      @gary44937
      hi folks, is it ok to place these bearings in boiling water in order to fit them on to the shafts. have had to replace the gearbox on my vauxhall vivaro van at 23,000 miles and am now recon the old one .
      #15812
      gary
        @gary44937
        #212956
        John Rudd
          @johnrudd16576
          I think I would be asking the bearing supplier/manufacturer…….
          #212960
          gary
            @gary44937
            i did they said to put them on with a press which i dont have.
            #212962
            John Stevenson 1
              @johnstevenson1
              No problem, they can stand far more than 100 degrees C
              Sorry to hear you got bit by the gearbox bug. You would have thought that by now they would have sorted the problem. An RAC guy told me about a year ago they have gone thru over 100 gearboxes.
              #212964
              Chris Evans 6
                @chrisevans6
                It may depend on the plastic. Nylon absorbs water and therefore increases in size. They should by now be stable and return to size though.
                #212966
                gary
                  @gary44937
                  thanks john and chris for a very helpful replysmiley
                  #212971
                  John Rudd
                    @johnrudd16576
                    Posted by gary shepherd on 18/11/2015 09:21:46:
                    If you are nearby, ( hull? ) you are welcome to use my modest 6 tonne press.
                    #212979
                    gary
                      @gary44937
                      Thanks for the offer john but to far away.will try booling them!
                      #212988
                      Russell Eberhardt
                        @russelleberhardt48058
                        Might be safer to heat them in oil, after all that's how they are used. Might be worth putting the shaft in the freezer as well.
                        Russell.
                        #212989
                        John Rudd
                          @johnrudd16576
                          Posted by Russell Eberhardt on 18/11/2015 11:15:58:
                          Russell.
                          Chip frier?wink
                          #213063
                          gary
                            @gary44937
                            boiling water did the job fine, replaced all 8 bearings to make sure. was going to sell it to recoup the cost but after what john posted i will keep the box as a spare.
                          Home › Forums › Workshop Techniques › Topics
