Parting off stainless hex bar
Home › Forums › Beginners questions › Parting off stainless hex bar
  • This topic has 3 replies, 3 voices, and was last updated 5 May 2019 at 12:28 by vintage engineer.
  • #407816
    Keith Matheson
      @keithmatheson47708
      Hi. I have been parting some 19mm across flats stainless and a bit unsure as to feeds and speeds when starting to cut. After the flats have been removed by the tool I found about 480 rpm with ‘sensible’ hand feeding worked well ie cuts well, sounds happy nice crisp sound. However, when I start to part the hex parts sound dreadful as the tool smacks itself into the tool at high speed.
      I have a Toolco lathe which looks identical to the warco 290. I’m using a rear tool post with a (carbide?) indexible type tool bit (glanze I think). I dribble cutting oil on it with a brush. Basically when it starts it sounds like I’m hammering seven shades of **** out of the tool bit and need to know if I should a. Slow it down initially b keep it as it is or c speed up for the first cutting part.
      many thanks Keith mm
      #9652
      Keith Matheson
        @keithmatheson47708
        #407821
        ega
          @ega
          It's normal for the initial interrupted cut to be noisy. You could consider taking off the flats with a front-mounted HSS tool at slower speed and then move to the RTP at your favoured speed and feed.
          #407823
          vintage engineer
            @vintageengineer
            Start slow until the bar is round then treat the same as round bar.
