One evil, but easily overlooked, gotcha when parting off with tools held in QC or 4 way tool posts where the cut axis is significantly offset to the tool post fixing is the significant twisting force on the whole assembly. I've lost a couple of parting blades and an insert holder that way when the QC post shifted slightly under the temporary extra loading of a chip hanging up. Both times in difficult materials.
Fairly sure that the root cause in my case was using synthetic cutting oil. Rocol Ultracut at book dilution to be specific. The stuff eventually gets everywhere, is seriously slippery and a right pain to clean off fully.
Finally twigged to that problem after wondering for several years why my Pratt Burnerd 180 mm precision 3 jaw chuck, bought new and not abused, didn't seem too be holding as well as it used to. Full strip & rebuild didn't fix the problem so I showed the gripping faces to a fine rotary wire brush. After some fairly aggressive attention the faces looked good and subjectively had a proper "plain metal" feel. Instant fix. Grip back to what it always was.
A more common reason for tool posts being prone to twist is top slide distortion. Its important that the post sits down on the outer parts of its base rather than close to the centre. Clearly the further out from the centre the main contact points are the more leverage it has against twisting. Most tool posts have the centre relieved to help ensure that. However the relieved centre provides no support to the topside around the stud so after many years the top can distort slightly significantly reducing full pressure contact area. This is quite likely with Tee slotted top slides when used with a short Tee nut. Especially so if the nut is shorter than the relieved centre portion of the tool post base. Much better to use a long Tee nut extending the whole width of the slide. The top slide on my big Pratt & Whitney had suffered badly in this fashion. Had to re-work the whole Tee slot, both top and bottom, for a secure hold and plenty of contact area. Previous owners just used a bigger spanner which eventually proved counter productive.
A thin card or alloy "gasket" under the tool post often helps as being able to deform slightly to take up small errors.
Clive.
Edited By Clive Foster on 14/06/2018 09:26:08
