Parkside (Lidl) Cordless Angle Grinder
Home › Forums › Workshop Tools and Tooling › Parkside (Lidl) Cordless Angle Grinder
Viewing 25 posts - 1 through 25 (of 45 total)
  • #453172
    Russ B
      @russb
      I picked up a £29.99 cordless angle grinder (no battery, no charger) as I already had a 4Ah battery and charger that came with the £59.99 400nm impact gun (which is a superb quality piece of kit, and its got some serious oomph, way more than any pneumatic hand held gun ive used!)
      Back to the grinder….
      2 issues, the no load speed is only about 7500rpm, not the 10,000 advertised, I didn't charge my battery (as I dont intend on using it and long term storage outside of 30-60% charge is very damaging for a lithium pack). My 3 bar battery indicator shows full, however these show full at anything over about 30% from what I've read online, so not to be trusted. I'll charge it up tonight and see how it goes.
      Issue 2…
      It's easily got the worst on switch I've ever seen, horrible wobbly bit of plastic that latches in at the end with a nasty sharp feeling hook thats held in by the spring tension of the switch trying to return to the off position. The side of the "slot" that the thumb switch slides up and down is notched on one side so assuming you're right handed, its like a sort of safety feature, you have to guide the wobbly switch away from it, as your right thumb naturally pushes towards it – no "safety" for lefties I guess! Its pretty awful, and its the looseness of the switch and the sharp cheap catch feeling that makes it so. It frequently gets caught on something and won't move from off, must be a notch or catch under the button that cant be seen, perhaps you're supposed to press it in before you slide it.
      The casing plastic is cheap, sharp looking flashings etc.
      Overall, looks nice, but the quality is absolutely no where near that of the big 400nm impact driver I bought. Bit of a let down to say the least. Although it was only £29.99 and I've got the battery and charger and I'm sure it'll do exactly the job its supposed to – I'm still tempted to take it back.
      This one is the newer version that looks the same as the old one, but the battery is at an angle to the body – not sure if thats any different.
      Anyone else got one, what are your thoughts?
      #19634
      Russ B
        @russb
        #453179
        Ady1
          @ady1
          I would take it back and wait for the corded 240v angle grinder if I were you
          The corded one is fabby, like the impact gun, a pure pleasure to use
          I use a battery drill driver, they have incredible low speed torque, that battery compressor is great, the battery impact guns are weak but great for general nut and bolt work
          Of course this may be the one tool that saves your a** one day because it is so portable…
          My main worry would be whether it has enough high speed grunt to cut properly, which is harder to achieve for a battery than low speed grunt
          A small grinder disc cuts up to 3 inches away from the power delivery centreline which is very different from drilling holes and screwing screws
          GL
          #453197
          larry phelan 1
            @larryphelan1
            Those grinders are a heap of crap. My friend bought one [ignoring my advice ] and found that it would not accept a grinding disc, only the cutting disc which came with it and lost power after a very short time.
            Best left alone.
            #453200
            Robert Atkinson 2
              @robertatkinson2
              Don't keep one in your car or carry it around. You are committing the crime of "going equipped" or to be exact
              "A person shall be guilty of an offence if, when not at his place of abode, he has with him any article for use in the course of or in connection with any burglary or theft."
              Applies to a lot of tools of course but battery grinders are used a lot for theft including bikes and catalytic converters.
              #453218
              Anonymous
                Posted by Robert Atkinson 2 on 20/02/2020 12:43:39:
                Rubbish, offence is only committed if it can be proved it's intended for something illegal- burglary or theft. Just having a battery angle grinder is not any kind of offence.
                #453235
                old mart
                  @oldmart
                  I'm a bit out of touch with recent Lidl diy stuff, is the grinder 12 or 20V?
                  #453241
                  Ady1
                    @ady1
                    They are congregating most of their kit around a generic 20v system at the minit
                    so some stuff can be sold without a battery+charger
                    most of my stuff is the old 12v system but I need lighter kit because of thumb and wrist trubbles
                    The 20v system will be more powerful but there's a weight penalty to deal with
                    Edited By Ady1 on 20/02/2020 16:47:14
                    #453242
                    Russ B
                      @russb
                      Ady, I'm cuffed to bits with my 20v impact gun (the biggest of 3 or 4 models they did) it's extremely powerful and top quality, mag alloy casing etc. I've got a 240v grinder I already (B&Q pro, done a hell of a lot of mileage over the last 10 years, getting noisy now, never serviced it….) I was buying this cordless grinder based on the quality of the impact gun.
                      Larry…… Yeah, you've hit the nail on the head I think.
                      I'll check this will take a grinding disk but I don't think it matters, it's going back, the poor quality of the plastic switch alone is an indication of everything else, CLEARLY not cut from the same cloth as the 400nm 20v impact gun.
                      Old Mart the 12v stuff I've seen just doesn't have the guts, but some of it is extremely portable, perfect for light tasks, general screwing drill driving die grinding etc.
                      Lesson learnt, even though the range of 20v powertools from Lidl use the same battery charger, they are clearly not all made to the same standard, take each one in your hand and judge quality! (Wasn't possible in this case, they were all cable tied shut)
                      Ahhh well…
                      #453244
                      Ady1
                        @ady1
                        I missed that impact gun Russ, lucky you, I will look out for it
                        Got the corded gun which has yet to be defeated by a wheelnut or anything else
                        #453251
                        Russ B
                          @russb
                          Posted by Ady1 on 20/02/2020 16:53:34:
                          Well worth keeping an eye out for it just make sures it's 400nm and not the 300 or less, it's motor is 4x the size!! I had to take a big 32mm nut off my dad's van that hasn't moved since 98' and has andbeen well soaked in road salt, it blitzed it straight off, me and him were getting ready for a fight. It hit it so hard it damaged the flanks of the nut even with a good 6 sided impact socket (which wasn't welcome but we know to dial it down a bit next time, it has a digital torque selector on the grip, a button cycles through them)
                          #453253
                            Posted by Mick Berrisford on 20/02/2020 14:46:15:
                            Not rubbish at all. To get a conviction, the prosecution only has to show you're away from home, have the tool, and have an intent to use it. In practice showing 'intent' is woolly, down to a court to decide. A tradesman with a legitimate reason for having tools in his van is much safer than a youth caught going into a bike shed with an angle grinder up his jumper.
                            Better to have a solid reason for having the thing than to claim it's not a crime until they've proved intent. Won't be a problem if the officer is persuaded, otherwise he'll have you down the station, an unpleasant time-waster even if they subsequently decide not to proceed.
                            Best advice about the law is to steer clear. Although it's amazing what ne'er do wells get away with, the full weight of the law tends to fall on anyone rich enough to pay fines whilst being too poor to pay a QC. My local paper often reports yobbos going equipped getting Community Orders, whilst a middle-class gent is fined £500 for letting his dog foul the footpath.
                            Anonymous
                              Posted by SillyOldDuffer on 20/02/2020 17:26:53:
                              You are obviously ignoring the first line of what I called rubbish " Don't keep one in your car…You are committing an offence" which is total rubbish. Your interpretation/opinion has nothing at all to do with my reply which was just to the point that it's wrong. I don't need your barrack room lawyer spouting off with a lecturing "what's what", I know what I'm on about and I was right in what I said, actually dealing with the offence many times over 30years in the police helps a lot.
                              #453258
                              Mike Poole
                                @mikepoole82104
                                Ideal to have in the car if you get clampeddevil
                                #453262
                                Robert Atkinson 2
                                  @robertatkinson2
                                  I stand by what I said, please don't edit what I said to suit your case.
                                  While guidance is that there will normally not be any action without intent, the lettter of the law does not require it. The law (Theft act 1968) also says that possesion of an item made or adapted for burglary or theft is considered intent on it's own. Obviously the case of one in your car depends on you being in or near the car and not at home.
                                  The point of the wording of this law is that it's does not need proof of intent, if it did it would be too hard to enforce. It's basically up to you to show reasonable cause for having the item.
                                  Hopefully it is applied with reason, but you could end up on the wrong side. Try not to fail the "attitude test" for startrers. Finally it's not the police who decide what is an offence or who is guilty.
                                  Robert G8RPI.
                                  #453273
                                  Anonymous
                                    What have I editted that makes any difference to your misleading post? Since when has having angle grinder in your car makes it made or adapted to commit theft/burglary.?
                                    #453278
                                    Robert Atkinson 2
                                      @robertatkinson2
                                      Posted by Mick Berrisford on 20/02/2020 19:42:07:
                                      You removed "or carry it around" leaving just the car part.
                                      I just quoted the law on made for or adapted items, I did not say that a grinder met that test.
                                      You are just reading what you want to see, not what is there, I won't be responding further to this.
                                      Edited By Robert Atkinson 2 on 20/02/2020 20:03:51
                                      #453280
                                        Mike,
                                        Your choice of words is unnecessarily aggressive. Using the word 'Rubbish' on Robert and accusing me of being a 'Barrack Room Lawyer spouting off' is surely excessive. Try to keep it polite please.
                                        Nick Hulme
                                          @nickhulme30114
                                          Posted by Robert Atkinson 2 on 20/02/2020 18:16:33:
                                          Robert G8RPI.
                                          Complete and utter bunk, if you have no previous and are of good character you need have no fear in carrying anything which isn't illegal in itself, no one will be interested.
                                          #453327
                                          martin perman 1
                                            @martinperman1
                                            Gentlemen,
                                            Once again a resonably interesting post has turned into a barrack room brawl, does it always have to end this way and spoil everything. We all have our opinions whether right or wrong but dont spoil the post, do it somewhere else.
                                            Martin P
                                            #453350
                                            larry phelan 1
                                              @larryphelan1
                                              Don't think that "grinder" would get you into any trouble since I doubt if it would last long enough to cut anything !
                                              Looks like junk
                                              Feels like junk
                                              Is junk.
                                              #453353
                                              Circlip
                                                @circlip
                                                Glad I don't have a dog anymore, ALWAYS kept a rounders bat in the door pocket with his ball. Projected the ball a far greater distance than my aching joints could.
                                                Regards Ian
                                                #453374
                                                old mart
                                                  @oldmart
                                                  I have several of the Parkside 20V tools, the combi drill, the drill without the percussion, the SDS hammer (excellent), the jigsaw, (not great) and the vacuum cleaner (very portable doesn't hold much, especially swarf off the mills, bags have to be ordered from Grizzley in Germany, but a boon for keeping all the batteries in good condition by using them rather than just storing them). These use the 20V Team batteries, not the very similar ones they sold with the brushless 20V tools.
                                                  I also have one of the 12V angle grinders which is very good for small jobs where a full size one would be too big. It uses the little 75mm discs and the second generation 12V batteries
                                                  #497742
                                                  Cornish Jack
                                                    @cornishjack
                                                    Back on topic, I bought one of the complete kit versions (from memory) around £80. Expensive, but the no-wire was appealing. What swung it for me was that reassuring Lidl 3 year guarantee. It remained unused for several months and then showed its value on a 'one-off' job. A few weeks later I charged it up for another job, hit the switch and 'click' but no whirr! Checked the battery – absolutely fine. Covid arrived, so no shop visits. At long last, yesterday, managed to get to Lidl to return under guarantee – waste of time!! Their much vaunted "3 year guarantee" is not what it seems. The inevitable 'small print' informs that the item is only guaranteed for return to store "for 12 months". Thereafter it has to go back to the manufacturer (Chinese??). Caveat emptor, indeed!
                                                    Looking at the case securing screws, there are two, in particular that are very deep set (anti–'fiddling' device?). Have any members delved inside or have any tips for doing so? Might just as well have a look-see in case it is bodger fixable.
                                                    TIA
                                                    rgds
                                                    Bill
                                                    #497748
                                                    iNf
                                                      @inf
                                                      Hi Bill
                                                      Have you tried ringing the warranty line? Last time I had something go wrong with Lidl/Aldi goods after 12 months they swapped it out at no cost. May be worth a call before taking it to pieces.
