Came across this problem while re-fitting new return crank, I used a cap head screw (2.5 m.m.) and steel nut, but it will not tighten, just wondering if anyone has a suggestion? Possibly incompatible nut (7ba.) I have copied the original part( and consulted the drawings) but the original builder decided to make a split and fit a nut and bolt to grip it to the shaft. I did have the engine running with this method, but the return crank "moved" (engine would not go!) any suggestion gratefully received. Also is there a "fool-proof" way of setting the return crank in the right position in respect to other parts of the motion? Thanks in anticipation!
