New Use for Cone Drills?
Home › Forums › Hints And Tips for model engineers › New Use for Cone Drills?
  • #174736
      A purely random observation, the included angle of my cone drill exactly matches the 8-degrees of an ER25 collet, but its maximum diameter is only 3/4". This may not seem important, but it could be a useful tip for anyone planning to make a holder for ER16 collets!
        Bazyle
          @bazyle
          Other sizes of cone drill are available.
          but 5C are so much easier to cater for.laugh
          #174775
            Neil,
            Sorry if this looks like a hi-jack, but your thread seems convenient place to post:
            I just found these interesting arbors & toolholders, which fit into ER holders.
            mike T
              @miket56243
              MichaelG,
              Thats interesting. Now we can fit an expensive Genswiss toolholder into an inexpensive ER collet.
              Is that progress? I liked Neil's idea better.
              #174778
                Mike,
                I was thinking more of a DIY clone.
                … it was the idea that I liked.
                Bazyle
                  @bazyle
                  Makes a lot of sense. After all just the equivalent of making a morse shaped saw holder instead of a parellel shank one to hold in a morse collet. Cut out the middle man and remove one set of errors.
                  Following on it is interesting that we so take it for granted that a lathe spindle will have a morse taper but rarely use it as such and slap in an adaptor. It just needs someone to take the plunge and make retrofit spindles with ER noses.
                  #174783
                    Posted by Bazyle on 04/01/2015 23:37:29:
                    Makes a lot of sense. …
                    … It just needs someone to take the plunge and make retrofit spindles with ER noses.
                    yes
                    In the little Jason lathe that I'm fettling, Brian Perris almost took that plunge [except that he was using a conventional dead-length collet]; and, of course, Watchmakers lathes commonly use collet-shaped solid arbors.
                    The really clever bit about this one is the way they 'twist' the solid body into the ER nose cap [which is designed to take a springy collet] …
                    Have hope, Bazyle; there is at least one firm doing retrofit ER headstocks for the Sherline lathe, so maybe the light will be seen.
                    Edited By Michael Gilligan on 05/01/2015 06:20:26
                    Edited By Michael Gilligan on 05/01/2015 06:25:00
                    #174794
                      I have played with boring the Adept spindle for ER11, but for various reasons I think MT0 will be a better solution, although I won't go quite the whole way in with the bore as it would leave the spindle nose a bit thin.
                      Interestingly MT3 and ER25 have very similar gauge and small-end diameters so changing over to ER25 would not be difficult, except, of course, for machines with a flange rather than a screwed nose.
                      colin hawes
                        @colinhawes85982
                        I would not consider using a cone drill to produce a machine taper because only luck will give concentricity. It could be useful though for carefully cleaning up any damage. Colin
                        #174863
                        Bazyle
                          @bazyle
                          I thought Neil's original suggestion was for a storage holder – as per the HSM forum suggestion on their 'shop made tools thread'.
                          BTW is _Paul_ a member here?
                          #174870
                            I suppose I was think more of something I saw on a woodworking site. A light handle that took an ER16 collet at the end for holding various gouges and wood-turning tools, but although I doubt you could cut a full socket with one I think it would work as a 'poor mans finishing reamer'.
