Neilson air line fittings
Home › Forums › Help and Assistance! (Offered or Wanted) › Neilson air line fittings
  • #460228
    john fletcher 1
      @johnfletcher1
      I've looked on the net for Neilson air line fitting to match up with my existing ones, other makes won't seal properly. Can some one recommend a seller. John
      #33559
      john fletcher 1
        @johnfletcher1
        #460272
        David George 1
          @davidgeorge1
          I don't recognise Neilson as a standard for couplings try looking on here and try and match up one of these.
          David
          #460378
          Dave Halford
            @davehalford22513
            They use non standard fittings like the Aldi / Lidl compressors. Some people have found euro fittings will work on Chinese stuff, whereas I have not.
            The threads that these fittings screw into however are standard air line so you can swap them.
            #460384
            Oldiron
              @oldiron
              Amazon do these. But spelling of name slightly different. Neilsen.
              Personally I would change to PCL or similar known makes.
              regards
              Edited By Oldiron on 28/03/2020 11:04:31
              #460394
              Martin Cargill
                @martincargill50290
                A couple of years ago I was in the workshop swapping air fittings between tools, because I didn't have enough QR fittings to go around. I identified the fittings I needed but then discovered that the PCL type fittings (as used in most industrial garages etc) were far cheaper than the type I was using, so much cheaper that it was more cost effective to replace all of the fittings in my workshop (about 15 air tools etc) instead of buying the small handful that I needed.
                Martin
