For anyone thinking of using rubber mounts, the rubber, ideally, should be in shear. In tension, failure is likely to follow. Exhaust mounting "rings" are usually oversized, to minimise the tensile stress, but they do fail.
Engine mounts, in shear, fail much less frequently, if at all, as long as they free of oil.
