Thanks again for the replies!
Yes, this is old enough to be the narrow (front shear) guided. I have read the other posts and article (Radford) on the topic of modifying it to so called wide guide. I might do just that as there seem to be good reasons for this.. even though as it is now, the saddle is not worn appreciably, so it is not a MUST.
I also read up on the way Myford did the grinding setup. This was however to compensate for wear, ie. making it concave, so it would take longer for wear to be a factor. Mine a little convex now, so I will scrape that in.anyway, despite understandably it doesn't do that much of a difference.. just want to get it right at this point. Haven't measured the verticals properly yet, but will do soon and then know how much it needs of a refurbish.
I will of course not leave the saddle "unblemished", and will give it a proper 20 ppi finish (try my best at least)
