Myford QCTP Recommendations
Home Forums Beginners questions Myford QCTP Recommendations
Viewing 15 posts - 1 through 15 (of 15 total)
  • #377353
    Guy Lamb
      @guylamb68056
      I realise I'm going over old ground with this request, but could anyone recommend a good quick change tool post/tool holder system for my ML7. Looking through the ME archive I've found reference to 'A & R Precision' QCTH who, on the face of it have gone into liquidation.
      There seems to be quite a few to choose from internet wise, including some of which that don't have a very favourable write-up (in the archive).
      Guy Lamb
        @guylamb68056
        #377355
        Zan
          @zan
          There’s been a really good one featured recently in ME
          #377366
          Tony Pratt 1
            @tonypratt1
            I & many others have been on this ‘journey’, although I had no problem using the original Dixon manufactured tool post in industry for many years the far eastern clones on offer today are not made to the same high standard & this can cause operational problems.
            For that reason I recently sold my collection of little used Dixon type QCTP & holders & changed over to the Arc Euro trade wedge style lathe tool holding system.
            As it uses a different type of clamping system any minor size differences from holder to holder do not affect the clamping strength.
            Obviously others will have different stories to tell.smiley
            Tony
            #377473
              Out of interest Tony, which size did you choose? The 000 is ideal for mini lathes, is it a good match for a Myford too? The 100/111 seem a bit OTT for a 3 1/2" lathe.
              Hillclimber
                @hillclimber
                Must be the 000, according the Arc Euro site? Ketan seems to offer an 'adaptor' kit to replace the toolpost pin etc on a Myford for this size….
                Cheers, Colin
                #377477
                alan-lloyd
                  @alan-lloyd
                  multifix system every time, check it out.
                  #377479
                  Hillclimber
                    @hillclimber
                    I am myself a recent recruit to (Chinese) Multifix.
                    #377480
                    Mike Poole
                      @mikepoole82104
                      As Tony says the Dickson system has been undermined by poor quality copies from some Asian manufacturers. The spacing of the V guides is critical and the relationship of the tee slot for the clamp and the V has to be held to tight tolerance or the holder will not lock and stay locked. There is something of a range of prices and you would hope the more expensive clones would be ok but it may be better to look elsewhere especially as most people build their toolholder collection incrementally over time and getting ones that fit may not be straightforward.
                      #377481
                      John Baron
                        @johnbaron31275
                        Hi Guys,
                        I've just made a "Norman patent toolholder for my Myford S7B. I should have done this years ago.
                        No modifications to the lathe, just removing the old tool holder and replacing it with a 38 mm diameter post. I also made a new nut to get rid of the ball handle.
                        #377489
                          Hey don't spoil the Normal Toolholder article in the next MEW
                          Tony Pratt 1
                            @tonypratt1
                            Yes it's the 000 size I'm using. Multifix & it's clones looks good but they aren't cheap.
                            Tony
                            #377548
                            John Baron
                              @johnbaron31275
                              Posted by Neil Wyatt on 24/10/2018 20:35:10:
                              Might pay you to drop me a copy of the article then !
                              I have a complete set of drawings based on the original patent. Though I have published my design in a number of places.
                              #377578
                                dont know Is that Normal and/or Norman ?
                                John Baron
                                  @johnbaron31275
                                  Hi Michael,
                                  I hadn't noticed the spelling error !
                                  Thanks for pointing it out !
