Myford ML7 clutch
Myford ML7 clutch
Home Forums Manual machine tools Myford ML7 clutch
  • #599026
    Peter Marquis-Kyle
      @petermarquis-kyle57199
      I have recently become the custodian of an ML7 of late 1970s vintage. The lathe belonged to my late father who bought it, still in its crate, from the original owner. The lathe has sat unused for a long time, since my father found it difficult to use after he suffered a stroke.
      I have started to clean and check the lathe and I found a few bits are missing, and I am seeking some advice.
      The lathe is fitted with the Myford clutch assembly, but the clutch will not engage. I see that one small part, shown in the parts diagram and list, is missing: Part No A1803, Operating Rod.
      I am guessing that this operating rod is just a piece of round steel rod, with rounded ends. If so, it's something I can easily make, rather than trying to obtain a genuine Myford part — I should mention that the lathe and I are in Australia.
      If somebody here can tell me some basic details and dimensions of the clutch operating rod I would be very grateful. And, if my guess is wrong and the piece is more complicated, I would welcome correction.
      Cheers, Peter
      #14569
      Peter Marquis-Kyle
        Missing operating rod
        #599032
        Jon Lawes
          @jonlawes51698
          For those interested the part is shown in the picture below. I think the answer is in this post here:
          https://www.model-engineer.co.uk/forums/postings.asp?th=159839
          Bootlegger Blacky wrote: "Hi, I have just removed this pin to measure for you,and it is round hard bar,rounded at both ends,and is…29.1mm. Long and 3.16mm.width. Thanks"
          (Right click the image below and open in a new tab to make it clear enough to read)
          Edited By Jon Lawes on 24/05/2022 07:10:12
          Edited By Jon Lawes on 24/05/2022 07:10:57
          #599045
          noel shelley
            @noelshelley55608
            From the above post 1/8" silversteel might be good as the ends could be heatreated – just a thought ? Noel.
            #600151
            Peter Marquis-Kyle
              Thank you all! That's exactly the help I was looking for!
              #601503
              Bootlegger Blacky
                @bootleggerblacky
                You’re very lucky to have a clutch. Someone suggested using a masonry nail !
