myford ml2 gears
myford ml2 gears
Home Forums Beginners questions myford ml2 gears
  • #361335
    les peacock
      @lespeacock91391
      I know the gears from myfords ml7 and ml10 will fit the ml2 which has a 5/8th diameter drive hole, so does that mean any gears with a centre hole of 5/8th diameter will be ok
      #9251
      les peacock
        @lespeacock91391
        Suitable gears for myford ml2
        #361337
        Hopper
          @hopper
          No. The gears need to have a diametric pitch of DP20 (basically, that's the size of the teeth) with a pressure angle of 14.5 degrees, with the 5/8 centre hole.
          You could use ML7 gears on an ML2 but you will have to drill the small hole for the drive pin that the ML2 uses where the ML7 has the keyway.
          #361339
          les peacock
            @lespeacock91391
            Thanks
