myford big bore thread
Home › Forums › Workshop Techniques › myford big bore thread
  • #659826
    andrew davies 3
      @andrewdavies3
      I am looking to make some slave chucks for a myford big bore and i have found that its a 42.5mm x 2mm thread. I can cut a 2mm thread changing the gear to 34T and using 18 setting on the gearbox. My main question or anything else you could help with is what angle would i be best to use (55 or 60) and what angle for the compound.
      Many Thanks
      Andy
      #16470
      andrew davies 3
        @andrewdavies3
        #659832
          It's a metric profile so 60deg
          Myself I don't angle the top slide but 29.5deg if you do
          #659834
          andrew davies 3
            @andrewdavies3
            Thanks jason
          Home › Forums › Workshop Techniques › Topics
