MYFORD 254 LATHE TECHNICAL QUESTION
Home › Forums › Manual machine tools › MYFORD 254 LATHE TECHNICAL QUESTION
  • #455578
    ray jones 1
      @rayjones1
      HI ,
      Can anyone advise me please
      On the Myford 254 lathe (any variant) Feed shaft from the multi speed gearbox to the saddle / apron.. When using Power feed or cross feed, as a safety measure, is the drive protected by a shear pin or adjustable slip type clutch?
      On some Lathes such as the Myford 280, there is a user adjustable slip clutch built into the saddle. so it acts as a safety measure , or if you are using a bed stop will trip out when the saddle reaches the bed stop..
      I have checked the manual and can't find a reference to it.
      Appreciate the advice , thank hyou
      #13791
      ray jones 1
        @rayjones1
        QUESTION FOR EXPERTS
        #455587
        duncan webster 1
          @duncanwebster1
          On mine there is a clutch at the left hand end of the hexagonal shaft. I don't think it is adjustable. Page 41 of manual item 27 refers. I've never had the nerve to just drive the saddle into a dead stop, but I think that is the idea. It wouldn't work using leadscrew
          Edited By duncan webster on 05/03/2020 19:41:21
          #455588
          ray jones 1
            @rayjones1
            Hi Duncan ,
            thank you will check my manual again .
            Agree we are talking feed shaft only
            .kind regards ray
            #455592
            MichaelR
              @michaelr
              On my 254s the clutch is at the same position as on Duncan's lathe, but mine is adjustable it has a "C" spanner that has two lugs that engage in slots in the clutch and was supplied with the lathe when I bought the Lathe from Myfords.
              MikeR
              #455604
              duncan webster 1
                @duncanwebster1
                Just had a close look, mine has a slot right across which could be used to tighten it up perhaps? Page 22 of the manual refers, but nothing about adjusting it. Does your manual mention it Michael?
                #455608
                lfoggy
                  @lfoggy
                  There is definitely a clutch on feed shaft which can be used when turning to a dead stop. Works well.
                  #455609
                  MichaelR
                    @michaelr
                    Posted by duncan webster on 05/03/2020 21:43:25:
                    Duncan, My manual doesn't mention anything about feed shaft clutch adjustment, The tool list for the lathe includes a Slotted nut spanner (Feed shaft adjusting) which came with my lathe.
                    MikeR
