Motion Plate and Link Bracket Problem!!!!
Home › Forums › Beginners questions › Motion Plate and Link Bracket Problem!!!!
  • #63312
    StirlingSingle
      @stirlingsingle
      Hello….
      I have found that I am strugaling to get my motion plates in the right place relative to the main cylinders. They are two high if i line them up with the holes in the frame (Link Bracket lining up hole??) detailed on the plans. Is it best to put them on this line and file the top down or just to lower them. Does a bar go all the way through the frames? Any ideas appreciated..
      Many thanks.
      #5388
      StirlingSingle
        @stirlingsingle
        #63314
        peter ravenscroft
          @peterravenscroft57700
          on what engine please
          regards
          peter
          #63315
          StirlingSingle
            @stirlingsingle
            Sorry, its a Simplex
            Many thanks
            #63334
            John Baguley
              @johnbaguley78655
              Looking at my drawings shows that when the bearing bushes for the expansion link are lined up with the holes in the frame, the top of the motion bracket should be flush with the top of the frames. Looks like something is not quite right somewhere. Either the alignment holes are not in the right place (should be 1.09375″ from the top of the frames) or the expansion link bushes are in the wrong place on the motion bracket. As you suggest, the idea is to put a length of bar through the holes in the frames and then through the expansion link bushes on the motion brackets.
              The position of the expansion link pivot bushes is the critical issue. If they are too high, the radius rod will be angled up relative to it’s correct position, which will affect the valve events. Also, of course, the slide bar mounts will not line up with the slide bars!
